Pump stopped at 4 gallons. What's up?
Discussion in 'Gen 2 Prius Main Forum' started by ewxlt66, Apr 13, 2013.
  1. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    I had driven 456 miles so I knew I MUST get fuel.
    Pump shut off at 4.5 gallons but I knew it couldn't possibly be full.
    I check my average fill up is about 7.5-9 gallons, so I nursed the pump until 8.6gallons and called it a day.
    This ever happen to anyone?
  2. arnesto
    arnesto Junior Member
    24
    San Diego
    I had a pump turn off where my mpg would be 65 so I drove 1.2 miles to the next station and put in 2.5 more gallons until that pump clicked off. That brought my actual mpg to 51 which was normal. I guess it does happen.
  3. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    A common problem in Gen2 Prii. There is a bladder in the fuel tank that tends to produce back pressure during fills. Some pumps are sensitive to back pressure and shut off early. This problem tends to be more prevalent in cold weather when the bladder stiffens.
    Take care not to accidentally overfill the tank as the carbon canister that controls fuel vapors can get polluted.
    JeffD
    richard schumacher and ewxlt66 like this.
  4. Kory Matthew
    Kory Matthew Junior Member
    37
    North Dakota
    I have run into pumps that are just finicky too, where they will stop at 1 or 2 gallons and I know I have used at least 7 gallons. It's happened in other vehicles too, some pumps are just weird.
  5. sturgidson
    sturgidson Junior Member
    35
    FL
    I'll have this issue regularly as well.
    In other threads, folks have mentioned "burping" the bladder... can somebody explain this again, or direct me to a thread that can explain it? Is it related to this issue? How does one do it? Thanks
  6. turnbowm
    turnbowm Junior Member
    So. Calif.
    I started having problems with incomplete fill when low-vapor nozzles were implemented in California stations several years ago. Did a little research and concluded that the problem was caused by pressure buildup in the tank during the fill process. The solution for me was to fill up with the pump nozzle fully inserted, but with the nozzle seal (rubber) pulled back slightly from the tank filler opening. Using this method, I haven't had any more problems.
  7. ewxlt66
    535
    186
    Dana Point, CA
    I'll give it a go. Thank you.
  8. Opihi
    Opihi Junior Member
    23
    San Gabriel
    Yup, I've started having this problem too. The first time it happened I can only fill up 2 gal. The next fill up was better tho, to almost full.
  9. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    Sometimes, it's just a matter of bad timing.
    Pump nozzles wear out and must routinely be replaced.
  10. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    My Gen II constantly popped when filling. I finally discovered that if I put the pump in upside-down that it will fill all the way without a problem.
  11. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    One advice that helped my Gen 2, Open the gas cap before doing any paying at the pump, the more time you give that tank, the less crabby it is.
  12. ewxlt66
    535
    186
    Dana Point, CA
    I'll end up trying all of these probably. :)
