Pump valve replaced, MPGs up!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by thisboy47, Jan 25, 2014.
  1. thisboy47
    thisboy47 Junior Member
    So. Cal.
    My check engine light was throwing the code P1121 for the coolant flow valve. Toyota replaced it under a warranty enhancement (I have 134k on it), and since then my mpgs have gone from 46 to 50.
    My AC is working much better now, too. My theory is that the valve can be in a semi-failure mode for a long time before throwing a code. Now that My coolant is flowing the way that it should, heat is being disappated more efficiently.
    Any thoughts or anyone with a similar experience?
    PriFi likes this.
  2. JC91006
    16,501
    8,413
    what enhanced warranty covers this at 134k miles?
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Water flow valve? Is it is a thermostat?
    What's the part listed on your receipt?
  4. thisboy47
    So. Cal.
    Coolant flow valve. Part 16670-21010.
    The check engine code was P1121.
    Under warranty until 150k at least here in CA.
    cwerdna likes this.
  5. Patrick Wong
    18,200
    6,479
    The impact of a failed engine coolant flow valve would include:
    1. The cabin heater may not function very well
    2. The engine may take slightly more time to reach operating temperature since the coolant heat recovery system would not be functioning.
    I would not have expected a failed valve would impact mpg as much as you have noticed. Perhaps some other factor is contributing to the improved results.
