Purchase a set of disks, what size?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Ghostwraith, Jul 18, 2016.
  1. Ghostwraith
    Ghostwraith Junior Member
    Slovakia
    I am thinking of buying a set of disks for the winter. It is recommended in the technical document 6.5j*15.
    how to find out more detailed specifications of the disc? nuts diameter of 5? Wheel offset?
  2. Mendel Leisk
    38,207
    I have a few notes on what I went with, for our 3rd gen, should be the same:
    Corolla steel rim, part no: 42611-02471 (2003-2008 corolla or matrix, CE, LS, S)
    steel rim lug nuts, part no: 90942-01007 (plain, open-ended, galvanized)
  3. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    The stock wheels are 6Jx15 ET45, 5x100 bolt pattern, 54.1 mm center bore. That's the specs you'll want for winter wheels.
  4. Mendel Leisk
    38,207
    Is there an offset spec that matters too? Think I've heard 38 mm?
  5. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    ET45 is the offset spec.
  6. Ghostwraith
    Slovakia
    6,5Jx15 ET40 5x100, correctly for prius gen 4?
