Purolator still considered not so great?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Stevewoods, Sep 1, 2016.
  1. Stevewoods
    Stevewoods Senior Member
    648
    993
    Seattle, WA
    There was some discussion about Purolator filters having declined quite awhile back.
    Time for an oil change, and while I can get other brands, Purolator is the easiest to secure where I travel. With a little effort and a detour off my normal routes, I can get Wix or Napa or Carquest, but again, if Purolator has straightened up, it's the easy purchase for me.
    I would buy a Toyota filter if I needed to go to dealership for another reason, but just for a filter, it's too much hassle.
    49,490
    you can get toyota online.
  3. 09Prius2
    09Prius2 Member
    201
    88
    FL
    I thought purolator was supposed to be good. They used to make AC Delco filters, which are now made by Wix, also Napa and Carquest are made by Wix. I would use the purolator and cut it open after the oil change. If the filter media inside has not collapsed after one oil cycle than it is the way to go.
  4. Stevewoods
    648
    993
    Seattle, WA
    O.K.: Instead of working this afternoon (hmmm), I spent some time going through old PC posts and found what my feeble brain must of had stored away. And, it was not that long ago. In this post from last winter, it seems that Purolator was being dinged, so I suppose nothing has changed in the past several months.
    I will go ahead with the Napa Gold for $6 and change (although my cheapo self is tempted by the Napa Silver for $4). I like Napa well enough, but it always seems like I get behind two people who need numerous special order parts and it takes some 20 minutes to get in and out.
    Better than the dealership, though, if I can buy an oil filter and be in and out in 45 minutes, that is a special day.
    Purolator oil filters -- can anyone give the 30-second scoop on the brand | PriusChat
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Don't know why its such a big deal to go to the dealer? Just buy 3 filters at the same time. There the best bet and cheaper than the crap your buying now.
  6. bisco
    49,490
    45 minutes to buy an oil filter? where you going, the dmv?:p
    edthefox5 likes this.
  7. 09Prius2
    09Prius2 Member
    201
    88
    FL
    I did alot of research today and found that the Denso filters are some of the worst you can buy, bare minimum filtration at best however better than none. The purolators still seem to be among the best of the widely available filters, and the new boss filter looks like the best on the market out of what is commonly available at auto parts stores.
    The wix filters are not recommended at all, slightly better than factory filters yet the inside is all cheap cardboard glued together, without a solid cap at the end of the filter.
  8. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    I am with above...order 3 OEM filters from a Toyota dealer on line.
  9. William Redoubt
    William Redoubt Senior Member
    1,215
    1,165
    Coronado Island, California
    You can buy genuine Toyota via Amazon, along with crush washers and oil ($95 case). I usually order on Wednesday for Friday delivery with Prime.
  10. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Show me your research please. Link please.
  11. Mendel Leisk
    38,726
    How far are you from a Toyota dealership?
    I don't even think about it, every 6 months, pick up the oil (Toyota), filter and drain bolt washer at a Toyota parts department. Try to do it when we're driving by anyway.
    #11 Mendel Leisk, Sep 3, 2016
  12. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    What?? Nobody claiming Fram is garbage and the worst filter ever made? I've used them for years and never had a problem.
    What I would find interesting, would be an impartial study (not funded by a manufacturer) that could show the results for the name brand filters. Unfortunately, this is unlikely to happen.
    In the meantime, I think the suggestion to use a toyota brand filter is as good as any and possibly better than many. But who do you suppose makes their filters?
  13. Stevewoods
    648
    993
    Seattle, WA
    Toyota dealers here are not located well for me. So, Toyota is a no-go -- and as said, it takes forever for parts service at the one dealership I have used.
    Mailorder and my rottweiler do not mix.
    Found this interesting web page, which compares Toyota to Wix -- on a Toyota dealer site:
    Oil Filter Comparison - Tundra OEM Filter vs Fram vs Wix
    So, off to Napa for a Napa Gold.
  14. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Conclusion is the Toyota filter is the best value.
  15. bisco
    49,490
    but near impossible to come by in seattle.
  16. William Redoubt
    1,215
    1,165
    Amazon and Amazon Prime still deliver to Seattle. In fact, rumor has it that Seattle is their HQ.
    edthefox5, m.wynn and bisco like this.
  17. 09Prius2
    09Prius2 Member
    201
    88
    FL
    I didn't save any links but its all over the internet for all to google.
    Fram is garbage and I've seen it many many times. I worked in a garage for years and I didn't see problems with any other filters like I did with fram. One filter literally had to be shredded to shrapnel in order to be removed. While fram filters work because some filtration is better than none, as a company they are nothing more than a marketing sham promoting a vastly inferior product. Even their upgraded filters do not rate well. The only good thing is the sure grip coating, which I admit is a nice feature, but has nothing to do with the performance of the product as intended.
    You can find plenty of people online who have bought a variety of filters and have done various experiments and dissection. I haven't read one yet that said you should use fram. They mostly say the opposite, which has been my professional experience as well.
    The Toyota brand filter is made by denso in thailand. It rates very poorly for filtration, however it is designed for toyota specifically so there is at least one advantage here. I had a dealer oil change done recently, so I'm interested to see what the filter looks like inside after removal.
  18. bisco
    49,490
    idk, without anti indy lab testing to prove otherwise, i'd rather use the filter spec'ed by the company who has to cover the warranty claims.
    #18 bisco, Sep 4, 2016
  19. Mendel Leisk
    38,726
    Yeah but the single Seattle dealership is atop Mt Baker.
  20. bisco
    49,490
    and amazon hasn't begun the rotweiler safe drone deliveries yet.
    edthefox5 and Mendel Leisk like this.
