Purpose of Air Intake Reservour PN 17750-37010?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NoMoShocks, Mar 1, 2012.
  1. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    81
    Camas, WA
    Anybody know what the reservour PN 17750-37010 attached to the Air Intake does?
    It has three small ports between the reservour and the air intake. This part is very light as if their is nothing inside the box. I took it out to work underneath it, and of course, I put it back where it was.
    Presumably, it uses the three ports between this reservour and the Air Intake to exchange Good Vibes with the air going into the air cleaner.
  2. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    On most cars it is used to smooth out airflow and reduce intake noise.
    Using intake systems with the box usually results in more noise and a sucking sound. In sme cases it also cause screwy MAF readings and cause my AFR to wander and in 2 cars the cars ran like hell or stopped altogether. lol
  3. Bob K.
    Bob K. New Member
    23
    Baltimore, MD
    Yes, smooths out flow, and it really quiets the intake down by cancelling out many frequencies. These parts are designed to hold a very specific amount of air volume to do this.
