Purpose of rear seat vents?
Discussion in 'Prime Technical Discussion' started by PiPLosAngeles, Sep 15, 2022.
  1. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,550
    720
    What is the purpose of the upper vents on the driver and passenger side in the rear seats - the ones that would be next to a passenger's shoulder? When the car is charging the cooling fan is going 100 miles per hour and the plastic trim below the bench seat is hot (the jack storage compartment and the jack itself are really hot), but there is no sign of any airflow from either vent.
  2. schja01
    schja01 One of very few in Chicagoland
    1,746
    1,162
    Chicagoland
    2018 Prius
    Check the filter on the right side of the rear seats down low.
    Marine Ray likes this.
  3. Marine Ray
    Marine Ray Senior Member
    1,139
    941
    Sparks, NV
    The upper vents are air intake for the two cooling fans in the rear to air cool the traction battery.
    The two intake and outlet vents below the rear seat are to air cool the charging equipment under the rear seat.
    Unless you have very high ambient temps your description of whats happening are concerning. I'd have Toyota take a look.
    Louis19 likes this.
  4. PiPLosAngeles
    1,550
    720
    The filter below the seat appears brand new. There's no dust on it. You can plainly feel the air being sucked in from the passenger side vent below the seat. It is also being sucked in through the vent below the seat in the center. There is no clear exit. There is no vent on the driver side. There is no perceptible air flow from either shoulder-level vent.
  5. ChapmanF
    15,614
    Battery cooling air exits the car, through vents concealed by the rear bumper cover.
  6. PiPLosAngeles
    1,550
    720
    I wonder why the plastic trim below the seat gets so warm, and the jack itself even though there is clear air flow?
  7. Louis19
    Louis19 Active Member
    379
    339
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    If you want to know all about traction battery cooling and charger cooling here is an interresting link that could answer your questions. ....very detailed info p.s popcorn will help you viewing this video:)
    in a nutshell the traction battery vents ouside the car, the charger vents inside the car
    2017-2022 Prius Prime - Retrait de la batterie de 8,79 kWh - YouTube
    #7 Louis19, Sep 17, 2022
    KMO likes this.
  8. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
    This is from the owners manual.
    D6F91227-A138-440A-956F-C1A95A41F980.png D31804D7-6D5D-4056-AAB1-6BDD5790767B.png 85B58612-0391-4AFE-A356-9F60437FA071.png
    Tideland Prius, Louis19 and Zythryn like this.
