Push clips for lower side panel of Prius v 2015
Discussion in 'Prius v Accessories and Modifications' started by Ohid, Sep 29, 2020.
  1. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    I lost push clips of lower side panel which attached underneath the body of my Prius v 2015. How do I keep it attached to the body? What is its part number? Here is a link for photos.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,500
    Taylors, SC
    Toyota part # is 76924-47020
    icyrius and Ohid like this.
  3. Mendel Leisk
    41,909
    OMG that's a new high (low?) for fastener price. Aren't head bolts around $10 apiece?
    I have some of those fasteners either broken (still there but missing bits and loose), or gone. And some of the odd rectangular block outs not looking quite right.
    But: it all manages to hold together, looks good standing beside the car; I'll take it lol.
  4. Georgina Rudkus
    3,513
    2,500
    Taylors, SC
    Here's the other one;
    The cheapest repair is to drive a self drilling screw an inch or 25mm to the side of the hole. Then just cover the hole with a piece of Gorilla duct tape.
    Putting the can on the lift, with the lift arms on the plastic rocker covers, pull the clips off.
    icyrius, Ohid and Mendel Leisk like this.
  5. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Thanks
    icyrius likes this.
  6. Georgina Rudkus
    3,513
    2,500
    Taylors, SC
  7. Mendel Leisk
    41,909
    @Georgina Rudkus those links were not behaving for me: was that single clips or multiple?
  8. Georgina Rudkus
    3,513
    2,500
    Taylors, SC
    It's for 15 pieces.
  9. Georgina Rudkus
    3,513
    2,500
    Taylors, SC
    good and destroyed rocker clip.JPG 3m vhb mounting tape.JPG added rear tail screw.JPG I found out that the fastenings for the rear half of the rocker panel moldings are really inadequate. The bottom of the rocker panel moldings are retained by only two of the plastic push in clips space nearly 18 inches or 45cm apart. The rear end is not fastened to the metal of the body and flaps freely.
    The black nylon plastic clips deteriorate over time from UV damage reflected from the pavement over time so that the thin retaining edge breaks off (shown in red box) and lets go of the molding. Then the entire molding is loose.
    To fix this fault, I removed the clip plugs, put 3M VHB double sided mounting tape in the area between the two holes and replaced the plugs.
    To retain the tail end, I drilled and tapped the panel into the metal and fastened it together with an M6x1.0x10mm flange bolt. A self drilling and tapping TEK screw can be used, if one does not have the correct tap.
    Now, the rear of the rocker panel molding is securely fastened as Toyota should have done at the factory.
  10. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Problem solved. Here is photos.
  11. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
  12. Jarkko
    Jarkko Junior Member
    36
    Finland
    2012 Prius+ MPV
  13. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
