Push the OFF Button while moving!?
Discussion in 'Gen 2 Prius Main Forum' started by Black2006, Apr 14, 2006.
  1. Black2006
    Black2006 Member
    198
    Rolling slowly towards my garage tonight, I pushed the OFF button while still moving, and the car STOPPED!
    I mean, it stopped: the engine cut off, it went into Park and dark. Kind of a jolt!
    Not sure I like this: hope the Stop Button doesn't work at higher speed....
    P.S. Don't ask why I pushed it :rolleyes:
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    You must have been moving very slowly. I've never experienced this when moving. Usualy, just touching the power button does nothing when moving. Pressing and holding will do an emergency shutdown, even if you're moving fast.
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    at low enough speeds for it to Pin.. it will try. Anything above... maybe 5 or 8mph and it will not react to the start button. If you are traveling at high speeds and hold it for about 4 seconds, it will go into an electrical shut off mode. all manual.. car shuts off.. you coast in N with manual stearing and breaks with minor assist. the backup (one of) sytem i'm guessing.
  4. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    normally I like to buy a new car and do what ifs too, like get up to 45 in a ford elite and slap it into reverse or take a convertable through a car wash with the top down, howd it turn out? Not to good.. ;)
  5. SirGreen
    SirGreen New Member
    75
    <div class='quotetop'>QUOTE(Black2006 @ Apr 14 2006, 02:29 AM) [snapback]239611[/snapback]</div>
    I had another question. What if Your kid drops your key out of the window
    at high speed?
  6. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    <div class='quotetop'>QUOTE(SirGreen @ Apr 14 2006, 05:06 AM) [snapback]239634[/snapback]</div>
    Nothing other than you will have to turn around to go get it. However, if you turn off the car you will not be able to start it back up again.
  7. samoan_ridah
    samoan_ridah New Member
    You will also get an indicator warning you that the key is out of range.
  8. jamarimutt
    jamarimutt New Member
    985
    And why would your kid be playing with the car keys? :blink:
  9. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    While driving on a 400-mile round trip on the second day of Prius ownership, my 20-year-old son and I were wondering what would happen if two Priuses swapped their keys while moving. (Toss 'em across through open windows.)
    Now we know that both cars would just complain of keys out of range.
    We're both techies...whattya gonna do...
  10. finally_got_one
    finally_got_one New Member
    151
    Orange County, California
    <div class='quotetop'>QUOTE(Black2006 @ Apr 13 2006, 11:29 PM) [snapback]239611[/snapback]</div>
    In industry, such a feature is known as an E-STOP, or an emergency stop button. It is similar to turning the engine off in other cars. When my Honda Accord threw its timing belt at 70+( :rolleyes: ), I had to turn the car off, which of course meant power everything, including brakes, steering, windows, etc. Fortunately I was able to get over to the side before being hit.
    If you push the button that way, it is supposed to turn off. That is what it is designed to do.
  11. momfortheenvironment
    146
    Southern New Hampshire
    sounds like a shutdown!
  12. Tideland Prius
    16,157
    <div class='quotetop'>QUOTE(finally_got_one @ Apr 14 2006, 05:02 PM) [snapback]239932[/snapback]</div>
    Nope. That won't happen at 70mph. You have the hold the POWER button for 3 seconds before it'll go into ACC mode.
  13. Kev1000000
    Kev1000000 New Member
    271
    Livonia, MI
    Yea i've done a lot of testing with the power button.
    At speeds Equal or below 2mph, the car WILL shut of and be placed in Park if you hit the Power button.
    Anything over 3mph, the Power button does nothing with a quick depress.
    If you press and hold for about 4 seconds, the car will shut almost everything off INCLUDING power steering and regen braking. So the car is a lot harder to steer and brake. This will initiate at any speed above 2mph.
  14. finally_got_one
    151
    <div class='quotetop'>QUOTE(Tideland Prius @ Apr 14 2006, 08:25 PM) [snapback]240022[/snapback]</div>
    You are quite right. I was referring to my '91 Honda Accord (not my Prius!)...I had to shut it down when it threw the timing belt at 70mph by just turning the key. It was kind of scary, but I was able to get over to the shoulder ok.
  15. inlights
    inlights New Member
    South East Michigan USA
    A question along these lines. Both my wife and I have had engine runaways in other cars both parked and moving on the highway. What we did was just shut the car off with the key. HOW could the Prius be shut off in a emergency situstion? Will the power button shut the engine down in motion? and how fast? when this happened to me in another car the engine stoped and I had to use more force to steer but the car engine stopped in less than a second. The throttle was almost wide open. Any one have to kill the engine in a emergency in a Prius?
  16. larkinmj
    larkinmj New Member
    1,996
    <div class='quotetop'>QUOTE(Rick Auricchio @ Apr 14 2006, 02:28 PM) [snapback]239794[/snapback]</div>
    If you decide to perform this experiment, could you videotape it and post the video for us to view? :)
  17. Kev1000000
    271
    Livonia, MI
    <div class='quotetop'>QUOTE(inlights @ Jun 4 2006, 11:20 PM) [snapback]265801[/snapback]</div>
    Just press and hold the Power Button for about 4 seconds. The car will enter ACC mode, meaning power steering and all regen braking will turn off. Manual braking is still readily available, but it is quite harder to steer.
    The only power being used is from the small 12v battery. Not the hybrid battery. The ICE, elec motor, and hybrid battery are all turned off.
  18. KMO
    KMO Senior Member
    1,542
    425
    Finland
    2023 Prius Prime
    It's actually an interesting state you end up in - you're in ACC mode, but in "N", a state you can't normally reach. The dashboard is blank, except for the gear indicator on its own.
    When you reach a standstill, you can press "P" to park, and the gear indicator vanishes, putting you back into the normal ACC mode. You can't reselect "N" (without going to IG-ON or READY).
  19. pollocks
    pollocks New Member
    32
    Silicon Valley, California
    While on a 12 hour drive yesterday, we were discussing what would happen if the Power button was pressed while driving. Glad we know without having to test it :)
  20. RobN
    RobN New Member
    23
    Long Island, NY
    Can the car be restarted while still moving or do you need to stop and completely turn off first?
    Robert
