Pushing power button while moving
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dano, Aug 19, 2007.
  1. Dano
    Dano New Member
    Centerville, oH
    Anyone accidently hit the power button while driving?
    There has been much discussion re: the park button not engaging the pawl if over 3mph, but how about the power switch?
    A regular ignition key switch won't allow it, or if it does it locks the steering "BIG PROBLEM"!!
    Just wonderin!
  2. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    <div class='quotetop'>QUOTE(Dano @ Aug 19 2007, 05:21 PM) [snapback]498794[/snapback]</div>
    When did you experience the steering wheel locking in a Prius?
    JeffD
  3. Malarkey
    Malarkey New Member
    146
    Connecticut, USA
    There's another thread that talked about this as a tangent - IIRC, it puts the car in Neutral, as would shifting it into reverse while driving at a decent speed.
    I believe the thread also mentioned that it logs when things like that happen into the computer, which cracks me up for some reason.
  4. aaf709
    3,862
    2022 Prius Prime
    IIRC it goes to Neutral then Off. And it has to be pressed for a little bit; otherwise it just beeps.
  5. IndyDoug
    IndyDoug New Member
    120
    Indianapolis, IN
    It self destructs.
  6. patsparks
    10,664
    567
    Adelaide South Australia
    :eek: I read somewhere the "power" button acts as the control switch for the ejector seat in models with the standard factory sun roof if you press it while driving. :huh:
  7. geodosch
    geodosch Member
    182
    27
    New Jersey, USA
    2013 Prius Plug-in
    <div class='quotetop'>QUOTE(patsparks @ Aug 19 2007, 07:56 PM) [snapback]498866[/snapback]</div>
    There is no factory sun roof... though with the ejector seat you can quickly make one. :lol:
