Putting in a second push-to-start button
Discussion in 'Gen 3 Prius Accessories and Modifications' started by LazarusSyndrome, Dec 7, 2020.
  1. LazarusSyndrome
    LazarusSyndrome Junior Member
    17
    Indiana
    Hello, I work as a delivery driver and frequently forget to turn off my car when getting out which results in my Prius screaming at me so I promptly turn around, reach over the steering column, contort into an awkward position, press my face into the roof, and pretend not to notice how much attention I'm attracting as I claw around for the power button.
    My question is... How complicated is the power button? In my head it's just a positive meets negative situation and I'm just going to pry off some panels and solder another switch onto the positive and negative wires then whichever one is pressed completes the circuit.
    51,155
    why not just move the whole affair to the left side of the dash?
    Prodigyplace and Burna J like this.
  3. ASRDogman
    ASRDogman Senior Member
    7,245
    3,781
    Wouldn't it just be easier to remember to turn it off BEFORE you get out of the car? (n)(y):whistle:
    Georgina Rudkus and Mendel Leisk like this.
  4. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Use the power button to put it in park/shut it off at the same time. That’s how I broke myself of the bad habit of leaving mine on when I first got it.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,353
    2,347
    Taylors, SC
    Won't work, even if you wire the two switches in parallel. There multiple control wires that vary the voltage from to 5VDC. I've actually disassembled one to examine the circuit board. One switch's interference with the other would cause confusion to the computerized circuit. start button Gen III.jpg
  6. ChapmanF
    17,355
    Glancing in the wiring diagram (more info), it's got two different normally-open contacts, three LEDs, and a key transponder circuit. Ten connections to it. But maybe you don't need to replicate any of that but the contacts. As long as your fob battery works, you won't be needing to hold the fob against the button for the key transponder, and you probably don't care about the LEDs.
  7. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
    The best and easiest option would be to relocate the switch. It would mean getting 22ga multi-colored hookup wire, small diameter heat shrink and a lot of fine soldering. Personally I have quite a few Gen 3 start-stop buttons with some including the snap in plug and pigtail.
  8. ChapmanF
    17,355
    If it were my project, I might give it a go with an off-the-shelf DPST pushbutton and see how far I got.
  9. Mendel Leisk
    40,587
    This. Why mess up the dash on a whim?
    Georgina Rudkus and ASRDogman like this.
  10. ChapmanF
    17,355
    Live a little. The dash has lots of easily replaceable messable bits. You can get buttons that slip right in.
    If I remember right, open one of those up, it's a pretty common 3 amp DPST button inside.
  11. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    Pretty sure that mine "screams" the instant that you open the drivers door.
    Maybe the solution is to SLOW DOWN just a tiny bit.
