Putting into Neutral before Park?
Discussion in 'Gen 3 Prius Main Forum' started by motifone, Aug 12, 2012.
  1. motifone
    motifone Junior Member
    48
    16
    Hi All
    New owner of a IV here. Dealer advised the following procedure for parking car:
    1. Come to a stop, foot on break
    2. Put car into Neutral, make sure Neutral is lit up
    3. Then press the Park button.
    They said this is better for transmission. Didn't see a mention of it in the manual, and have no problem doing this, but curious if anyone does similar. Or are you just coming to a stop and then hitting the Park button, skipping the Neutral step?
  2. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    Never heard of it before, I rarely even press P. If you turn your Prius off, it is in P. I only use the P button when I am in a drive through and want to focus on my banking, not my car.
    Much More Better and PriusCamper like this.
  3. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    I second what Jimbo said. I am on my second Prius and can't remember ever using neutral. I usually put the car in park before turning it off, but sometimes I forget and just shut it off. I do use the parking brake about 99 percent of the time too.
  4. markabele
    5,084
    1,782
    Nebraska
    Just keep in mind that the dealer probably knows less than you do about a Prius simply because you come on here and seek out knowledge. A lot of them are lazy, greedy, slick, and not too bright. Obviously there are exceptions.
  5. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    When we got our first Gen 3 Prius, our dealer told us to put the car in park before pushing the stop button. We learned quickly that pushing the stop button put the car in park, with one less step. I have never tried neutral, park, and stop and see no reason for the first two steps. The neutral step could be disasterous if you we're interrupted during the shut-down process and walked away from the car in neutral.
  6. motifone
    48
    16
    Hmm, interesting. Dealer was an exception to the rule -- knowledgeable, nice, and competent with the car. Anyhow I'm still learning about the car. I'm sure this will all make more sense when I drive it a bit more.
    By the way, when I am playing & learning with features on the car (radio, nav, etc.) is it perfectly fine to do this in ACC (Accessory) mode (hybrid system not powered on)? The caveat being don't sit there for hours and drain the whole car battery like any other car?
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,193
    Nixa, MO
    There is no transmission in any traditional sense. And neutral only impacts electronics, nothing mechanical. Thus, the information he gave you is inaccurate. Simply push the power button, no need to put it in park or any other stated prior to that.
    Tech_Guy likes this.
  8. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    I wouldn't use the acc feature when playing with your new toys, the 12v in this car is a small one, used mostly to power up the electronics only. If you are going to be fiddling with the nav and other toys for more than a very few minutes, just leave the car on and the computers will take care of the batteries.
  9. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Ditto. To be more specific, leave the car in READY mode (READY light on), NOT IG-ON nor ACC.
    Like JimboPalmer, I've never heard the "advice" about going to neutral first before (I've had my Prius since January 06 and am rather active here on Priuschat. I seriously doubt that helps anything. I wouldn't bother.
  10. motifone
    48
    16
    Such a helpful forum. Good to know about not to tinker long in ACC mode. At first I was working in READY mode, then saw the battery graphic dropping, and started to worry, and so went into ACC for a short bit. I've since read more about the system, and just as you said, it's better to stay in READY mode and not ACC. Lesson learned.
    So if I'm sitting in the parking lot while the wife runs into the store for 15-20s mins, and I want to run the radio and/or A/C unit while I'm in the car waiting for her, then I just leave it in READY correct while I'm using the radio and A/C?
    What reason would anyone want to use ACC or IG-ON anyway?
  11. fuzzy1
    10,284
    Does that AC compressor (not merely the fan) even work outside of READY mode? It can drain the HV battery very rapidly, so you want READY and Park to allow the engine to resupply the battery. (Don't use Neutral, as it will disable the generators.) With climate control and lights off, the radio alone should be a smaller concern with a greater time allowance.
    But READY will force a cold engine to start within about ten seconds. When I'm spending a few minutes in a cold car in a closed garage, such as when configuring the car or GPS or entertainment system or ScanGauge, READY is the wrong mode to use. The 12V battery won't face much stress, but the exhaust fumes are a bad idea.
    PriusCamper likes this.
  12. PriusCamper
    PriusCamper Senior Member
    11,233
    4,588
    Pacific Northwest, USA
    Interesting thing about the park button... The 2 year old in me wants to push the park button while driving down the freeway... In the near half-million miles I've driven in my life I've never done anything as insane as that and at the same time I bet if I hit the park button at freeway speed in a Prius nothing would happen, right? Maybe if I knew the answer I could move on to other random thoughts about my car while driving? ;-)
  13. efusco
    19,891
    1,193
    Nixa, MO
    go ahead, nothing will happen. I think there's a beep that means "that was stupid", but it won't hurt the car. I think you have to be less than 7mph for it to engage.
    Tech_Guy and PriusCamper like this.
  14. PriusCamper
    11,233
    4,588
    I think I accidentally engaged park at 2 mph once and the experience made me cringe for days...
  15. efusco
    19,891
    1,193
    Nixa, MO
    yea, that jerking sensation is not nice.
  16. gmcneil05
    gmcneil05 Member
    118
    36
    Avon Park, Florida
    When I have to park on a hill I stop, put the car in N push the parking break in, let off the break and let's the car settle then park or ig off. This saves a load on the parking actuator when you go to take it out of park.
  17. efusco
    19,891
    1,193
    Nixa, MO
    That is probably a good practice.
  18. Munpot42
    1,391
    543
    Me I just turn the car off with my foot on the brake, then engage the parking brake before lifting my foot off the brake, don't think you need the extra step of going to neutral.
  19. fuzzy1
    10,284
    Besides the beep warning, it also instantly goes into Neutral. Shifting to Reverse at highway speeds produces the same result. Should one ever want Neutral right now (e.g. as an extra tool to stop an uncontrolled runaway acceleration, if that should ever really happen), these are faster ways to get into Neutral, bypassing the normal one second delay.
  20. PriusCamper
    11,233
    4,588
    Thanks... Never thought I'd see the day I could shift to park or neutral or reverse at freeway speeds and have it all go ok... I guess times have changed huh?
