Putting just about every accessory I can on my prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by BadComedy09, Jun 10, 2022.
  1. BadComedy09
    BadComedy09 New Member
    Michigan
    Right now I'm trying to figure out about putting a bull bar on my front end, and what all I might need, please help
    From hood ornaments to a trailer hitch for no reason,
    Everything.
  2. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Yes, you certainly need help and not from this forum.
    Glenn G and jerrymildred like this.
  3. Mendel Leisk
    41,545
    What’s the hood ornament already on there?
  4. Another
    1,819
    517
    Naples, Florida
    Ornaments, plural?
  5. BadComedy09
    Michigan
    That's a 1941 buick roadmaster,
    Also looking at a 1947 for the driver side headlight,
    Already got a 1949 studebaker for the passenger side
  6. PriusCamper
    PriusCamper Senior Member
    12,801
    5,188
    Pacific Northwest, USA
    If you pull the bumper cover off (see youtube) you'll find lots of solid objects to weld or bolt stuff to... And it's always better to overdo how strong the mounts are rather than underdo it.
  7. Leadfoot J. McCoalroller
    8,100
    7,581
    Pennsylvania
    2018 Prius c
    You can certainly attach one with some effort, but none are made with useful mounting systems that directly bolt up to a Prius.
    Please understand that it isn't going to be functional, if you actually nudge or push something the bar is likely to break off and increase the damage to the front of your car and possibly you as well. But it has been done. Rough overview:
    1. remove the front bumper cover
    2. fabricate some steel brackets with the right fittings for the bar- might be able to modify ones that come with
    3. attach your custom brackets to the crash beam (probably requires welding but you might catch an easier break)
    4. cut holes for the brackets through your bumper cover
    5. re-install the bumper cover
    6. attach the bull bar to the bracket fittings that are poking through the cover
    BadComedy09 and PriusCamper like this.
  8. Another
    1,819
    517
    Naples, Florida
