PWR SWITCH ?
Discussion in 'Gen 3 Prius Main Forum' started by Johnnu, May 31, 2014.
  1. Johnnu
    Johnnu Junior Member
    44
    I'm curious to know what the PWR mode actually does INSIDE the engine i.e. does it 'step up' the timing &/or fuel flow to the cylinders??? THANKS, J
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Nothing. The PWR mode only effects mapping of pedal position to throttle position.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It also affects the heating and cooling system.
  4. fuzzy1
    10,149
    The ECO button does, but I don't recall the PWR button doing so.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Right. The fact when it is in PWR negates the economical settings that could be had in ECO if that makes any sense.
  6. Tideland Prius
    16,125
    It'll increase the pedal sensitivity so the engine is more willing to rev up. There's a possibility that the voltage through inverter steps up to 650V vs. 500V in normal or ECO mode but it's never been documented in any Prius documents we've seen (but it has been mentioned in the CT200h documents which share the same hybrid powertrain as the Prius).
  7. fuzzy1
    10,149
    In this sense, PWR is the same as Normal. ECO is the 'different' setting.
  8. Johnnu
    44
    Ah So...........I think I understand; many thanks for the comments.... J
  9. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    It does one more thing. It makes the driver think he/she is in a powerful vehicle. ;)
    Les_PL likes this.
  10. El Dobro
    El Dobro A Member
    6,978
    3,213
    I don't remember where and when, but someone here posted a Toyota presentation on the New Gen IIIs and it showed there was a boost when the power button is used.
  11. sopclod
    sopclod Junior Member
    My wife and I have opposite tastes when it comes to cars... when she has to drive the Prius, I tell her "Push the power button right when you get in the car, then you'll be rocketing along unlike me..."
  12. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    PWR button use requires JDM neck brace...
    spiderman likes this.
