Q. carista odb2 for gen4 prius user
Discussion in 'Gen 4 Prius Technical Discussion' started by PRIUS MAX, Mar 1, 2017.
  1. PRIUS MAX
    PRIUS MAX New Member
    KOREA
    Question. I want to know all the menus that can be set in the 4th generation Prius.
    For example, display for mile-> km,
    avg. L / 100km-> km / L
    Is this change possible?
  2. pakitt
    pakitt Senior Member
    2,173
    1,311
    Colorado
    I didn't see that in the Carista menus when I connect my Gen4 to it. Customisation is very very limited, to what the user's manual says, essentially...
    RCO and bbald123 like this.
  3. PRIUS MAX
    KOREA
    total Setting menu Capture Screen shot possible?
  4. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    If you're in KOREA and the standard of measurement there isn't l/100km (I suspect it's km/l), talk to your dealer - they should be able to set your car to use the units correct for the country it is sold in. If not, contact your local TOYOTA.
    RCO and Prodigyplace like this.
  5. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    For the US 2016 Prius I only see how to change both the speedometer & economy between miles & Km.
    Some early 2016 US Prius (manufactured before February 2016, I believe) lacked this feature which causes issues for those travelling between the US & Canada.
    Perhaps your Prius cannot be changed. If I were you, I would take the advice of @alanclarkeau. . The dealer should not charge you since the vehicle is under warranty.
    #5 Prodigyplace, Mar 2, 2017
    RCO likes this.
  6. alanclarkeau
    7,044
    7,584
    Mine has no options (that I've found) as our country's measurement standard is l/100km which is what it's set for.
    RCO likes this.
