Q: Did 2004 Prius ever have a powered lift gate for hatch?
Discussion in 'Gen 2 Prius Main Forum' started by Toyotally04, Feb 26, 2022.
  1. Toyotally04
    Toyotally04 Member
    128
    16
    SoCal.
    I got this car after many family hand me downs.
    My hatch now is a death trap for those who dare stick their head in. It slams shut like a shark attack.
    Anyone know if any of the trim ever had OEM powered hatch lifts, even by remote?
    thx,
    Toyotally04
    Data Daedalus likes this.
    49,490
    unfortunately no. not ever an option. you can install new struts cheaply enough, and a few here have added an aftermarket lift. big job though
    Toyotally04 likes this.
  3. Data Daedalus
    Data Daedalus Senior Member
    1,022
    1,183
    Wembley, London
    To the best of my knowledge, powered hatch lift capability was never factory installed on the 2nd Generation (2003 to 2009) Toyota Prius.
    I do know some of the top of the range Japanese models had a TV built into the MFD (Japanese TV stations only, unfortunately). They also had a (20GB..?!) HDD built into the dash, where MP3’s could be uploaded and used as a juke box.
    The Swedish models had an electric heater element built in for windscreen de-icing during the winter months - it may have had heated wing mirrors too.
    None of the above features made it into the UK models, which was a shame.
    Source: iPhone 12 Pro Max 512GB ? Pro
    Toyotally04 and bisco like this.
  4. pasadena_commut
    pasadena_commut Senior Member
    1,493
    447
    Southern California
    The struts on mine still work, but only enough to hold the trunk up, it needs to be lifted slightly before it will open by itself the rest of the way. I think this may actually be close to the ideal amount of lift, since "full power" OEM struts flex the roof structure when the hatch is fully open, and that cracks the metal, and then water leaks occur. (Or maybe they flex it when the hatch hits the limit of its vertical motion while moving rapidly upwards, it could be that just holding the hatch up is not enough to cause cracks.) So perhaps you might want to replace yours with somewhat less powerful struts than the OEMS.
    Anybody know:
    The number of Newtons a new OEM strut is supposed to provide?
    The minimum number of Newtons provided by the struts which is sufficient to open the hatch and hold it open?
    When it came time I was considering just replacing one, to keep the total force low, but I fear that might cause a twisting force on the roof, so that it would do more harm than good.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,915
    Columbia, SC
  6. fuzzy1
    10,170
    I kept a previous hatchback long enough to replace the struts a couple times to prevent this 'attack'. The spouse still has another hatchback of similar vintage. I think I replaced its struts three times, now she just uses a broomstick to prop it open.
  7. bisco
    49,490
    mine lack some oomph on cold days. hit my head a few times, seen a few stars :unsure:
    dig4dirt likes this.
  8. Toyotally04
    Toyotally04 Member
    128
    16
    SoCal.
    Thanks for the responses.
    Just wanted to make sure there wasn't a Mandela effect.
  9. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    Just get a set of new struts. Ten minute self help repair.
