Q: Force electric air heater (after exhaust pipe heat exchanger bypass)
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by LinuxGuru, Jan 3, 2025.
  1. LinuxGuru
    LinuxGuru New Member
    Riga, Latvia
    I have well known problem with coolant leak in exhaust pipe heat exchanger used for quick heating. Faulty heat exchanger now bypassed with a pipe, yet now there is a problem with heating - it looks like almost non-existent during drives 15 - 25 min long (so far I had no longer drives after service made few days ago). Windscreen remains icy/foggy even at -1..-2C (30.2 .. 28.4F) for very long time because no hot air stream. Forcing strong air flow to windscreen (with button) helps a bit but its quite annoying anyway.
    Is it possible somehow to force air conditioning system to turn on electric air heater? I tried to raise internal temperature on climate control yet it changed nothing (possibly) because engine coolant stays at low temperature and air heater turns on only if outside temperature well below -1..-2C (30.2 .. 28.4F)?
    A/C is always on, auto fan speed mode.
    Thanks in advance for any suggestion(s).
  2. BiomedO1
    BiomedO1 Senior Member
    2,725
    1,456
    SacTown, Ca
    Your thermostat is probably stuck open, allowing hot engine coolant into the radiator before it gets up to temperture or you somehow looped-out your interior heat exchanger on the by-pass.
    Hope this helps.....
  3. LinuxGuru
    Riga, Latvia
    Biomed01, thanks for reply, you meant thermostat or valve, or this is valve with built-in (or connected to) thermostat?
    PS. Small update - air stays completely cold after 1 hour of drive (~50 km).
    51,027
    what's the electric air heater, heat pump? shouldn't have anything to do with your bypass, and should come on without being forced.
  5. Mendel Leisk
    40,470
    Did you approach dealership? Out of the time/miles limit for the TSB? Or unending "back order" issue with the part?
    There really should be a class-action lawsuit for this horse manure. Ditto for 3rd gen EGR.
  6. LinuxGuru
    Riga, Latvia
    Yes, I approached domestic dealer, unfortunately, in European Union its NOT warranty.
  7. Walid
    Walid New Member
    I'm having the same issue, I did a heater exchange bypass, I live in quebec and weather is the -15C, drove the car for 20 minutes, and still the air blown in the car is cool, no hot air, any ideas that can help
  8. AzusaPrius
    AzusaPrius Senior Member
    2,137
    900
    When you say "A/C is always on, auto fan speed mode"
    Are you saying you have the A/C button with the light on and not off?
    That would keep the air cool.
    Auto fan speed mode is fine but dont have the A/C button on, just turn the temp up to where you want it and keep auto fan mode on or do it manually.
    Also not sure if this is a feature for your model but if you take the car out of ECO mode, there might be an electric heater that will help with heat, I know GEN 3 has that feature.
  9. BiomedO1
    2,725
    1,456
    SacTown, Ca
    Well, If you did the bypass properly - your thermostat is probably stuck open. You need to plug in a scanner and monitor ECT.
    If your within the Toyota TSB criteria you should let the dealership fix it. How many miles on the car and was the coolant changed per OEM specifications?
  10. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Third planet from the Sun
    Autostart and warm up the car in the parking lot for 15 minutes.
    The engine coolant temperature reaches +40+50C degrees
    Get in the car, switch the flaps to the windshield heating.
    Hot air quickly begins to flow into the cabin.
  11. ChapmanF
    17,186
    Maybe something in this post and the ones following will spark some ideas. (The diagram in that post shows the JDM / Euro hose routing including a selector valve, which some other markets like US don't have. Swap the details accordingly....)
    It might be that drawing a careful diagram showing the exact placement of the bypass will shed light on the cabin heat situation.
    BiomedO1 likes this.
  12. Walid
    Walid New Member
    Thanks, i will try it today
  13. LinuxGuru
    Riga, Latvia
    Disassembled system, it was clogged pipe. Have no idea how so much dirt could enter closed system, probably through crack in heat exchanger.
    Brian1954 likes this.
