Q re: "jerky" shutoff of gas engine
Discussion in 'Gen 2 Prius Main Forum' started by lovebug, Feb 12, 2008.
  1. lovebug
    lovebug New Member
    Hello, Prius friends!
    Am getting ready to take in car for free oil/filter change & tire rotation
    at 5K miles. I was thinking of just doing myself but wanted dealer to
    look at an issue.
    Sometimes, when stopping at a redlight & the gasoline engine shuts off,
    it does so with a jerk or thumpy feeling. The first time it happened, I
    actually thought someone had bumped me lightly in the rear, but not.
    This does not always or often happen & I am trying to see a pattern, but
    don't. It seems to me in the past the car had always shut on/off silkly smooth that you wouldn't even know you had a hybrid.Of course, when I made appt., the dealer said come in & show the
    tech. what you're talking about. We all know it won't happen then. :)
    Has anyone else expereinced this? Is it normal? Am I nuts?
    Thanks!
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    This is completely normal. We see this posted as a question more than anything else. What happens is that the Prius engine is always stopped in a particular position that favors restarting with minimum emissions. If the computer misses on the first try, it runs the engine around and tries again. An extra try or two makes the engine shudder when it shuts down. You will see this happen more often with new engines and during cold weather.
    Tom
  3. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Yep. Tom's right.
    Sometimes the engine runs so quietly that you can't tell it's on. Much of the time, it shuts off so smoothly that it's difficult to tell that it's stopped. But every once and a while you get that jerky stop.
    Quite frankly, I would rather take notice of the infrequent jerky stops because it means that it's not the norm. Just think how different it would be if people posted that the shut-off was occasionally uncharacteristically smooth.
  4. patsparks
    10,664
    567
    Adelaide South Australia
    That jerky stop is telling you the HSD has just entered its most efficient operating mode.
  5. HardCase
    HardCase SilverPineMica, the green one
    408
    Kalispell, Montana
    As the others have said, it's normal. First time it happened to me I was stopped at a light and a big yellow Hummer pulled up very close behind me just as the ICE shut down, causing the shuddering sensation you've experienced. Initially I thought the Hummer had nudged my bumper, but when I got to my destination and checked there was no sign of damage.
  6. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    This is the best explanation I have seen. Thanks! Is there more where that came from in the technical threads that I didn't see?
  7. qbee42
    18,058
    3,074
    Northern Michigan
    Yes, there is a wealth of technical information floating about in the forum. Some of it is from me, which makes it suspect, the rest is from reliable sources.
    Tom
  8. perryma
    perryma New Member
    1,781
    Tennessee
    At first I thought you had cut and pasted my post! Yes I have the same thing going on with mine and it seems it is normal and maybe worse in cold weather. You will get used to it . I just consider it a smack on the behind from the environment saying ,"Hey good choice."
  9. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
  10. lovebug
    lovebug New Member
    Wow, thank you, all my Prius friends who answered!
    I was thinking it happened more when really cold out, but now I understand better and will not worry.
    Again, thanks so much!!!!!
    p.s. my husband asked to borrow my Prius to make a trip to Florida because his RAV-4 v6 gets about 20 mpg, and he figures he will save
    about $180 on the 2K mile round trip. Now I know the car is safe for a
    trip.
  11. ksstathead
    1,244
    243
    Kansas
    Make sure hubby bones up on P&G, SHM(super highway mode), Warp Stealth, Warp Neutral, etc. Not only will he save $, but it mitigates the frustration of the inevitable traffic delays. His worst mileage will come on the open freeway sections (unless he drives a bit slower than traffic).
  12. TonyPSchaefer
    14,816
    2,498
    66
    My wife and I can fly to my parents' house for about $120 apiece or take the Prius on one tank of gas. It's 375 miles door-to-door; easily within reach for Priapus. Round trip: $60 with gas left over.
