Qi charger in the cup holder cover
Discussion in 'Gen 3 Prius Audio and Electronics' started by Dejan, Jun 6, 2023.
  1. Dejan
    Dejan Junior Member
    Belgrade, Serbia
    If someone is interested: there is enough space in the cup holder cover on central console to put a Qi charger coil with its electronics. The coil must have enough power to charge the phone distanced a couple of millimeters without excessive heat (test it through the mouse pad e.g.). Also, to minimize interference with the smart key presence sensor you should put some Al foil under the coil.
    Montgomery and bisco like this.
  2. ASRDogman
    ASRDogman Senior Member
    6,091
    3,273
    Nifty! Seems like a lot of work though. (y)
    49,488
    FE5AA62D-B0A7-4E26-9FB5-1DCE38AB2538.jpeg That’s cool!
    here’s mine :oops:
