I recently purchased a 2nd set of TRD rims that have Toyota TPMS already installed. Can I program my car for 2 sets of wheels? I'd like to use the factory 15's for winter driving. I did order a Techstream cable, if that's how they are programmed. Thanks
The MiniVci will allow you to do it. You have to register the tpms set that's on the car, it's a function within the techstream programming. I'm unsure if all Toyota tpms are compatible with the Prius, you would have to check if the TRD wheels have compatible tpms sensors.
