Question about air conditioning power consumption
Discussion in 'Prius c Fuel Economy' started by ecoboxer, Sep 7, 2018.
  1. ecoboxer
    ecoboxer Junior Member
    Ontario
    Technology
    Simple question: I'm wondering if the electronic AC on the Prius C has variable power consumption, or if it is fixed. Meaning, when the AC is set to 2 degrees below outside temperature, will it consume less power than if it was set to LO? Or does it always have the same power draw regardless of the temperature it is set to?
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    AC's have an efficiency band. Usually they are most efficient nearing full heat transfer. But for something as small as a car, it is not really measurable.
    Now if you've got a shopping mall you're trying to cool, small efficiencies add up quickly.
  3. PriusCamper
    PriusCamper Senior Member
    11,104
    4,518
    Pacific Northwest, USA
    In theory not running your a/c full blast but at a much lower setting saves energy... But in practice maybe running your A/C at a low setting constantly is not as efficient as my preference, which is to run the A/C full blast very briefly at times when the car is going downhill, flat ground, not climbing a hill or starting from a stop. This tends to annoy my passengers, but keeps me entertained on long drives. :)
    I suspect the Hybrid Asst app has the data charts available to study this via their Hybrid reporter app. If you dig into it and research it more, please post here and let us know your findings.
  4. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    Awesome question!
    I went digging around to see if I could find anything on it-
    Toyota has this, which establishes that there are at least 3 compressors used over the years. The original belt-driven model, the ES18 electric compressor used on 2nd generation cars and the ESB20 model introduced on 4th generation cars.
    This thread from another forum suggests that the compressor has an integrated variable frequency inverter so it can run the scroll at different speeds for different loads, which would change the electrical power consumption.
    What I didn't find:
    • Does the c use the ES18 or a different compressor?
    • confirmation (anything more authoritative than a forum post) that the ES18 has a variable frequency inverter
  5. bisco
    49,488
    i don't use auto, but on manual, the higher the fan speed, the harder the compressor works. this has been documented by people with tech stream.
    on 'auto', it would fluctuate as the system works easier and harder as needed.
  6. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    I need to play with techstream one of these days. I've already got a laptop dedicated to garage pursuits and a Tactrix for my Subaru, so in theory I only need the software. Any pointers?
  7. bisco
    49,488
    sorry, no. i don't have it. just what i've read from the experts here. there are plenty of threads with good advice.
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The DC style inverters (like used in mini-split units) are common now. They still are their *most* efficient at high load with good temperature deltas. But are still efficient at light loads. You could argue even if the efficiency graph was perfectly linear throughout the load, that the overall efficiency would still be in favour of a full load because of the offset in power usage for the control electronics. If you use 1% duty or 100% the control electronics are still 100%. This is why most SMPS's have that close to nothing % efficiency for light loads. You're still burning power to control not burning power. Once you start regulating that overhead goes to noise and you get 98% to 99% efficiency. But at 0.5% load, you're 10% efficient lets say.
    If you look up the Energy Star qualifications sheet for various ductless units you'll see the same efficiency graph basically. Starts low then rises sharply and levels out but still goes up. Most efficient at high load but still super efficient at all loads you care about.
  9. ChapmanF
    15,614
    For the Gen 3 (liftback, anyway), there is a spreadsheet going around that has a bunch of reverse-engineered parameter-ID data that you can load one way or another into your favorite OBD-II scanner software and read lots of operating data from the car. One of the entries I programmed into my ScanGauge II was for the watts being drawn by the A/C compressor.
    From watching it while driving in different conditions, it has about a 10 to 1 power range ... it can loaf along at about 250 watts in really mild conditions, or about a third of a horsepower, and you scarcely hear it running. In the hottest conditions it'll use close to ten times that, or around 3 HP, and in those conditions it sounds a little like you clipped somebody's motor scooter with your right corner without noticing, and you're dragging it down the road.
    For conditions too mild for even 250 watts, of course it'll just cycle on and off like every other air conditioner always did.
    I suspect the power dissipated in the drive electronics is still only a small fraction of the total, even at the lowest power.
    The c is a smaller car than the liftback, and it might have a smaller-displacement compressor, and the wattage upper and lower limits might be different. If you get an OBD reader and the right PID definition, it's easy to observe it.
    -Chap
  10. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    Please correct me if I'm wrong, but I understand that the traction battery in the c is cooled against cabin air. I understand the liftback vents overboard.
    I just wondered if they were taking advantage of the relative overage in capacity to avoid another hole in the body.
    I've got a scangauge lying around, I'll be interested to learn what our c tells us. Thanks!
  11. ChapmanF
    15,614
    The gozouta flaps on the Gen 3 liftback are behind the rear wheel wells, concealed by the bumper cover. That space is all beneath the hatch floor deck. The way the nice comfy cabin air gets into that space, so it can eventually exit through those flaps, is through the grille next to the rear seat, the ductwork, and the battery, and out beneath the floor deck.
    -Chap
  12. Mendel Leisk
    38,726
    I set an XGauge on my ScanGuage, for AC Watts, and would occasionally watch it on our Prius (3rd gen hatchback, hopefully similar). the value would alternate between zero (when the compressor was not running) and various wattages, anywhere between 50 and maybe 300, in increments of 50.
  13. ChapmanF
    15,614
    Interesting ... I've rarely seen less than 200 or 250 on mine (it just cycles off for demand below that). But full power is well above that, by around a factor of ten. I'm also using a ScanGauge XGAUGE that I got from a spreadsheet here. I wonder if the scaling factor got changed in that XGAUGE at some point.
    The one thing about relying on reverse-engineered PID definitions....
    -Chap
  14. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    Good point. Simple math says a 20k BTU/hr system (completely typical for a small/medium car) should be drawing a lot more than 250W at full output.
  15. Mendel Leisk
    38,726
    It tended to run lower values in particular, in the following conditions:
    AC button off, and vent mode set to heat/defog.
    With the above settings, AC would often "stealth run", even though it was not officially on, no light on the AC button. At low, near-freezing temps it wouldn't. Also, there's a sensor that detects cabin temp, and IIRC it's also detecting humidity? Or there is another sensor for humidity? Repair Manual excerpt (3rd gen):
  16. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
  17. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
  18. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    Agreed
