Question about Air Fuel Ratio Sensor
Discussion in 'Gen 3 Prius Technical Discussion' started by daley, Apr 17, 2024.
  1. daley
    daley Junior Member
    Knoxville
    I have another thread going about my misfiring JDM engine I recently installed but wanted to ask a more specific question here.
    I downloaded an Ebay version of the wiring diagram and fault diagnosis manual and within it is a page for testing the air fuel ratio sensor, I added the page below.
    When I test the two sensors I have, they both are within spec on the first test but show open loop for the second test listed on the chart.
    Due to this not matching what the guide says I thought I might have found my fault, however when I test a brand new Denso one at the store it also gives OL for the reading.
    Am I reading the test wrong? Did they update something with the sensor for later years? I also tested the 2010 part they had at the store which was a bosch and it also gives OL for the second test listed. What am I missing?
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,975
    4,716
    Texas Hill Country
    It says 10k ohm or higher. OL on a meter is higher. A better meter might read something in the megohms but all they are looking for is high resistance over 10k ohms.
