question about charging and balancing.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SDunahugh, Mar 10, 2017.
  1. SDunahugh
    SDunahugh Junior Member
    51
    22
    Ohio
    would it save time to force charge till you get green bars (car running in gear with foot on break and gas)? I know it is only 80% but I have 4 cars to charge and balance this week. thanks in advance
  2. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    green bars don't mean chit. You have to take the HV battery pack apart to balance the modules individually.
  3. SDunahugh
    51
    22
    Ohio
    I use the hybrid automotive grid charger, guess i should of said that in the post.
    Raytheeagle likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,484
    Bay Area, California
    2019 Prius Prime
    That helps;).
    Are you just charging, or doing a full reconditioning? If doing just charge balancing, getting the HV battery as full as you can will reduce the time on the Hybrid Automotive Charger.
    4 cars to maintain seems like a good use of the Hybrid Automotive technology. What years and mileage are the 4 Prii at?
  5. JC91006
    16,501
    8,413
    Don't rush the process, do it correctly, just charge when you go to bed, it'll be charged when you wake up
  6. SDunahugh
    51
    22
    Ohio
    just charge and balance this time (full 3 cycle recon on all 4 cars in 3 months). I own 2 2007s 120k ish on each, my parents own 2 2008's dads is around 100k moms 120k
  7. SDunahugh
    51
    22
    Ohio
    after about 1 year (once every 3 months) 2 recons a year 2 charge and balance. moms car is getting 10mpg better, the other 3 cars 5-7 mpg better
  8. Raytheeagle
    11,251
    15,484
    2019 Prius Prime
    How long have you had the charger and discharger? How many full reconditioning cycles have you performed?
    We have a 2010 Prius II with over 150 k miles on it. Have done one charge and balance. Waiting on the new intelligent discharger to arrive early next month and will perform the first reconditioning cycle over Memorial Day.
    I'll be bulbless(y).
  9. JC91006
    16,501
    8,413
    I don't think people should mess with their batteries unless you feel the performance has deteriorated. Every time you discharge below 7.2v, you are potentially damaging the cells. You only should do that when necessary, when the pack is out of balance or seem really weak.
    The car was designed to have a maintenance free battery
    edthefox5 likes this.
  10. SDunahugh
    51
    22
    Ohio
    reconed all 4, 2 times. this will be the 3rd charge and balance (the very 1st time I just did a charge and balance on all 4 the light bulb thing scared me a bit) bought a int. dis-charger, I wouldn't buy one for 1 car but since i have 4 it was worth it
    WilDavis likes this.
