Question about DICE playlists?
Discussion in 'Gen 2 Prius Audio and Electronics' started by sdp1969, May 11, 2007.
  1. sdp1969
    sdp1969 New Member
    I have a question about the DICE integrated HD/IPOD module in a 2007 Prius.
    When I connect my ipod do I have to make a new set of playlists in my car or does the DICE unit detect the playlists that I have make through itunes. Additionally, if it does detect the list of itunes playlists from the ipod does it display the playlist name that I gave it in itunes.
    Thanks,
    Steven
  2. aaf709
    3,862
    2022 Prius Prime
    On the 2005 the DICE detects the playlists you've made through iTunes. When D2 is selected, you can move up and down the playlists using the up and down buttons on the steering wheel. It does not display the name of the playlist, however. I don't know of any difference in the 2006+.
  3. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    <div class='quotetop'>QUOTE(aaf709 @ May 11 2007, 12:33 PM) [snapback]440140[/snapback]</div>
    Nope, no difference in a 06+
    It will show the first song on the playlist however.
  4. aaf709
    3,862
    2022 Prius Prime
    What I did was a suggestion I saw on this site. I went to AT&T's voice program and typed in the name of the Playlist and selected a voice. Then I downloaded it, gave it the name of the Playlist and put it as the first song. Then when I going between Playlists I hear the name. Plus, since it shows the title of the first song (when going between playlists), I see the name as well.
