Question about Fuelly???
Discussion in 'Gen 3 Prius Fuel Economy' started by Shaka808, Mar 6, 2014.
  1. Shaka808
    Shaka808 Junior Member
    I apologize in advance if there is already a thread on this, I did a search and couldnt find anything. I have a 2014 Prius Three and also use Fuelly to calculate mileage. On my last tank before fillup my Prius display registered 57.3 mpg. After I entered my fuel up data into Fuelly it displayed last mpg 52.9.
    Does anyone know why there is such a large discrepancy between Fuelly and the Prius display?
    walter Lee likes this.
  2. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    Calculated mileage is relatively accurate. The computer in the car is really just a guess based on fuel flow and other factors that add up to a lot of imprecision.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The Gen 3 Prius computer seems consistently high, about 5%
  4. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
  5. SudeepHArya
    SudeepHArya Junior Member
    46
    Jackson, New Jersey
    2014 Prius Plug-in
    Odd my fuelly is surprisingly higher then my Prius 2014 PIP. I was shocked but Fuelly is telling me I am getting bout 10% more then my PIP. That is why I came here to see if Fuelly was accurate or not. Your seeing it the other way so I am not sure what to believe.
  6. stoby9
    stoby9 Junior Member
    23
    16
    Austin, TX
    To test if Fuelly is correct simply take the # of miles you drove and divide that by the # of gallons you just refueled. That is all Fuelly does.
    If you accidentally entered 7.8 gallons instead of 8.7 (or something like that) then Fuelly will be off, but that would be your error. Also, if the pump shut off earlier than normal you could have a bad result because you did not actually fill the tank, but that type of error will resolve itself over the course of a few fill-ups.
  7. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    No one is questioning the accuracy of the calculation of mpg.
    They are speculating whether falsely elevated numbers are being entered into the site to boost certain vehicle's mpg numbers. Hence the use of the term "ringers".
    SCH-I535
  8. stoby9
    23
    16
    Austin, TX
    I don't see any reference to the term "ringers" in this thread, but I'll believe you since it's better than thinking that the concept of how Fuelly calculates MPG is such a mystifying subject. ;)
  9. xliderider
    7,869
    3,116
    Honolulu, HI
  10. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    As others have stated, the Gen III Prius is over reporting approximately 4 to 5% of the true actual MPG.
    But what is really important is the gallons you use rather than the MPG.
    Example 1: 20 MPG Car travelled 100 miles used 5 gallons of fuel. 50 MPG car travelled 100 miles used two gallons of fuel
    Example 2: 20 MPG Car travelled 100 miles used 5 gallons of fuel 60 MPG car travelled 100 miles used 1.67 gallons of fuel.
    Example 3: 20 MPG Car travelled 100 miles used 5 gallons of fuel. 75 MPG car travelled 100 miles used 1.33 gallons of fuel.
    The less fuel we burn benefits all of us except for big oil. Less oil being converted to gasoline. Less money being spent on fuel. Those are just two of the many benefits.
    Remember it is not just the MPG that is important, but also how many gallons you use over time.
    Ron (dorunron)
  11. walter Lee
    1,126
    376
    Maryland
    The Prius HSI display estimated MPG is only an estimate of your fuel efficiency
    The Prius HSI display estimated MPG is consistently optimistic by about 3 mpg
    Fuelly calculates your real world MPG when you fill up.
  12. neez
    neez Member
    194
    37
    My prius display is about 4% higher than actual. The display on cars is based on the fuel injection duty cycle data, so it's not entirely accurate by 4% is pretty good.
