Question about headlights
Discussion in 'Gen 2 Prius Main Forum' started by doogster, Jun 30, 2012.
  1. doogster
    doogster Junior Member
    65
    Hi. I just bought my 2nd used Prius today... this one is 2006 with 122K miles. It has bluetooth, the JBL stereo and a few other things my 1st Prius doesn't have. My question is... how do I know if this Prius has the regular light bulbs or the expensive headlight bulbs? Neither is out now, but I want to know what I have so when it does go, I can replace it.
    Also... if they are the expensive headlights... can I replace them both with the cheaper ones? ... or is the connector different so that I can't do that?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    2G Prius (2004-2009) Standard and Optional Equipment (Some Countries) | PriusChat
    People have said that if it has foglights, it has HID lights too. My 06 is package NL which is everything except for leather (and yes, I have foglights and HIDs). HID lights are white/bluish whereas halogens are orange/yellowish.
    When you turn on HIDs, you'll briefly see a color change at startup.
    No, you can't just put in a halogen bulb in an HID equipped car and vice versa. HIDs run at very high voltages and have a ballast. Not all HID Bulbs are created equal | PriusChat discusses HID systems.
    You'll have to do more work and buy a bunch of parts if you want to retrofit.
  3. doogster
    65
    ok... well, this one has the fog lights so looks like I have the expensive ones... figures.
  4. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Another thing to note, on HID equipped Priues, there's no separate filament or bulb or higher/lower brightness level for the high beams. There some sort of mechanism that moves forward/back depending on whether you're in low/high beam mode.
    (This isn't true of all HID equipped cars. My former Nissans w/HIDs had separate halogens for high beams. When in high beam mode, the halogens would turn on in addition to the already running HIDs.)
  5. doogster
    65
    so I see some bulbs out on Amazon.com for the 2006 Prius that say thins like "Xenon" and "Ultra" or "Platinum"... all these bulbs are around $30 each... will these work? Or does it specifically have to say HID?
  6. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Assuming Amazon sells genuine Philips D4R bulbs and not counterfeits, I'd stick with Amazon.com: Philips D4R Xenon HID Headlight Bulb, Pack of 1: Automotive. I'd buy only if sold and shipped by Amazon, not any 3rd party.
    I did buy two of the above (one to replace a failing bulb and another as a spare for the other) from Amazon WAY before 2K1toaster wrote his article. I don't think it's worth the time and money to screw around w/other random Xenon/HID bulbs.
  7. Tideland Prius
    16,445
    Turn on the light. If it's yellow (i.e. familiar looking), it's halogens. If you see a white/bluish white light, it's HIDs.
    And yes, typically HIDs came with foglights so that's a pretty good indicator to use.
