Question about heated seats on Prius C 4
Discussion in 'Prius c Main Forum' started by col127, Apr 16, 2012.
  1. col127
    col127 Member
    345
    Illinois
    hey everyone!
    had the opportunity to test drive a prius C four on the weekend and had two question about the heated seats - this would be to the folks who own a prius c four.
    #1 during the test drive, i turned on the heated seats to try it out. it heated up, but after 5 or so minutes, i noticed the heat went away - like it turned off or something. so i switched it off and turned it back on and could feel the heat again for a short amount of time. is that normal? seemed a little odd to me that it turned off that quickly.
    #2 how how does your seats get? i was frankly disappointed by how hot it got - it only felt warm at best... i am a little spoiled by my three level heated seats in my car, but still! :p
    thanks for any help!
  2. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    it's not supposed to get hot... it turns on and off to keep the seat warm.
  3. col127
    col127 Member
    345
    Illinois
    is it supposed to do that automatically?
  4. BrunoPuntzJones
    107
    28
    Don't have the manual, but wonder if "Eco" mode makes a difference with the heating capacity of the seats.
  5. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    I think ECO mode makes it cycle more and use less energy but it may get much more hotter if its off ECO as others mentioned. For me i feels good and not over done.
  6. Tideland Prius
    16,445
    It seems to be a "new" feature on Toyotas as my 2010 Prius' heated seats cycles the way you described (but our 2002 Camry didn't). It will cycle on/off which I assume is to conserve energy and to avoid burning your bum (at least on the 2010 Prius, I found it hot enough).
