Question about one more feature
Discussion in 'Gen 2 Prius Main Forum' started by momfortheenvironment, Mar 11, 2006.
  1. momfortheenvironment
    146
    Southern New Hampshire
    Does climate control mean cooling for when its hot in the car? Or is that why the heatshield is so hot? I should use less ac and I know even if it does exist it would affect gas use, but there are just some times when it gets really humid where I can see wanting it. Its hard to tell from the wording I've read so far?
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    huh? it's an automatic climate control. If you wante better mpg, shut it off. I find 72 during the day and 73 and night is comfortable. It controls heater and A/C.
  3. Tideland Prius
    16,445
    Yeah your post is a bit confusing. I'll attempt to answer what I think you're asking
    The automatic climate control is for both heating and cooling. Even though it says "AUTO A/C", it doesn't mean the A/C compressor is always on and it doesn't mean you're gonna be blasted with cold air when it's 0°F outside. The A/C compressor acts as a dehumidifier in the winter.
    Also, leaving it in AUTO A/C with the A/C button highlighted means the A/C compressor will be controlled automatically. It may or may not be on depending on the humidity sensor.
  4. momfortheenvironment
    146
    sorry I wasn't that clear, yes you both helped. Is there a manual override to the automatic controls?
  5. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    Yes. If you press the Climate button next to the screen you will get a picture on the touch screen which will offer you fan speed and temperature control among other things. These things are explained in your Owner's Manual.
  6. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    Since you don't have your location in your User Profile, we don't know if you are writing us from Duluth, MN or Yuma, AZ. That information can affect how or if some replies.
    Or is that why the heatshield is so hot? . . . Good question. Where are you located?
  7. momfortheenvironment
    146
    OH i added to my signature, I'm New Hampshire, where we get pretty cold and we get the hazy hot and humids in the 90's too.
  8. Tideland Prius
    16,445
    So yeah, what Allan said. There is manual override if you wish. The automatic climate control system on the Prius is quite sophisticated. It has a two-tiered climate control system. The Prius recirculates air at foot level to help heat up faster while it blows in fresh air in the upper vents so as not to fog up the windows.
  9. hjon71
    hjon71 Junior Member
    98
    So, for the record, for the best mpg AUTO on or off?
  10. cmwade77
    cmwade77 New Member
    116
    I find the MPG is about the same eiher way and it's more comfortable with it on, so might as well have it on.
  11. darelldd
    6,059
    389
    Northern CA
    Would depend on how you set things manually with Auto off. If you do the same things manually as Auto would have done automatically... no difference. If, however, you turn the thing manually off when Auto would have been running the AC compressor, you might see a mileage gain.
  12. cmwade77
    cmwade77 New Member
    116
    I have done precisely this (turning everything off even) and have seen no milleage gain)
