Question about radiator blocking
Discussion in 'Gen 3 Prius Accessories and Modifications' started by CaliforniaBear, Nov 17, 2013.
  1. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    If the Prius does not have a thermostat (mechanical or otherwise) that shuts of the coolant flow through the radiator until the ICE reaches operating temperature, then I understand the reason for blocking.
    However, if it does shut off the coolant flow until the ICE reaches operating temperature, then what is the reason for blocking?
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Air flow through the engine compartment cools the engine itself. Further, do remember, even with a thermostat closed some coolant flows through the radiator. There is a coolant bypass, as all engines require some coolant flow regardless of temperature. The main effect of blocking though is to hasten warmup.
    Even with the lower grill completely blocked Pearl S struggles to get the coolant up to 60C in the city. It gets close, then the engine is shut down and it drops. Good for fuel economy, not so good for getting nice and warm. Interior heat is fine though. I use the seat heat to help, and it is wonderful.
    Of course all this is at "non-California" temps, such as today, just above 5F, at -15C.
  3. CaliforniaBear
    1,180
    289
    Northern California
    There wasn't any coolant flow in my 1949 Ford until the temperature got to 160 (or whatever the thermostat was calibrated for). Things have changed since in the last 60 years :) I do notice the Prius takes longer to reach 130 even in our modest 45 degree temperature compared to summer at 70 degrees ++. I won't bother with radiator blocking.
  4. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    Electric water pump, heater valve and a lot of hose. Just because ICE is off doesn't mean the coolant fluid stop. Plus with the heater valve the system can route the coolant from the heater core first before it switches to the radiator system to cool the engine.
    1st heater core, then coolant system from what I can see.
  5. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    Besides the faster warm-up mentioned above, grill blocking improves aerodynamics. Smoothly directing airflow around the vehicle is more efficient than forcing it through a radiator, engine compartment, and out the bottom of the engine bay.
  6. Mendel Leisk
    41,934
    My take is the behaviour of the thermostat, the grill and radiator areas and so on, are designed for worst case: hottest summer temps, hill climbing, stuck in traffic with charge depleted, and so on. And in winter you can definitely close things up some.
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    At least up here, a huge benefit of blocking is it helps keep the road grime out of the engine compartment.
  8. Redpoint5
    1,026
    509
    Portland, OR
    FYI- I partially grill block my TSX even in the summer. Efficient driving means you are getting better than average fuel economy, which means you are generating less heat per mile than the typical driver. Since less heat is being generated, the cooling system is less burdened. This excess cooling capacity can be circumvented by grill blocking as long as one is careful to always maintain proper engine operating temperatures. I do this by setting an engine coolant temperature alarm on my UltraGauge.
    With a full upper grill block and an open lower grill, I never reach my alarm temperature of 200 degrees, even during the summer. One thing I have noticed is that 1 cooling fan always runs if I have the climate control turned on. This has the effect of cooling the engine, even when it is stopped in traffic.
  9. Mendel Leisk
    41,934
    ^ I can't see grill blocking when using AC for cooling. Seems similar to driving with a foot on the brakes.
  10. Redpoint5
    1,026
    509
    Portland, OR
    True, that is a consideration, and AC efficiency will be reduced by grill blocking. For my driving pattern and AC usage, I have noticed a significant increase in fuel economy by blocking half of my grill area during the summer. Apparently running the AC a little harder in Portland, Oregon is more than offset by a faster warm up time and reduced aero drag.
    Also note that there is a gap between your radiator and the grill opening of the car. With a fan running, air can still be drawn through radiators even when fully blocked. Since my a fan always runs when my climate control is on, air is always cooling the AC and engine coolant. Note that I drive a TSX; YMMV with a Prius, different climate, and different driving pattern.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Err uhmm, you do also track the MG temps as well.?
  12. Redpoint5
    1,026
    509
    Portland, OR
    I don't own a Prius, and I don't believe the UltraGauge has the capability of monitoring this. At least, I don't know how to set it up to do so. I'm in the market for a gen III though, so I'll be monitoring the MG temps when I get one.
  13. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Oh OK.
