Question about reserved capacity, which calculation is correct?
Discussion in 'Prime Main Forum (2017-2022)' started by Roy2001, May 30, 2018.
  1. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    I am interested to get a 2nd plugin hybrid and prefer a bigger one, so I went to Clarity forum. I argued with the guys there about reserved capacity. Here is the details:
    We all know Prime draws about 6.3kWh from wall, 6.3/8.8~=71%, so it reserves about 30% of the capacity not being used. Since EPA rating is 25 miles, (25/6.3)*33.6=133 MPGe which is what EPA rated as well.
    According to Clarity owners, it draws 14.7 kWh per charge with EPA 47 miles rating. (47/14.7)*33.6=107. this is pretty close to its EPA 110MPGe rating.
    14.7/17=86%. Now I told them that Clarity is only reserving about 15% of the capacity, they argue that due to conversion loss, the battery has only 12.5kWh charge even though it draws 14.7kWh. 12.5/17=73.5%, it reserves roughly 27% of the capacity.
    Now matter how, Prime reserves more capacity, hopefully that would result in longer battery life and less capacity lose. But I I wonder if their calculation is correct. Anyone can shed some light?
    52,351
    no, but it wouldn't surprise me. honda has nothing to lose, their hybrid/phev rep is already in the toilet.
    EyePrime and Dudley1030 like this.
  3. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    The Clarity does have one thing the Prime doesn’t: a liquid cooled battery.
  4. Tideland Prius
    16,611
    Keep in mind that both have hybrid modes so there's a portion of the battery dedicated to that too (I'll wager it's just under 1kWh on the Prime).
    One of John's video shows the Prime's EV portion is 14% to 83% true SOC. (It also means one doesn't have to worry about fully charging the Prime all the time since fully charge is 83% which is roughly what other EVs charge to for longevity either as an option ["standard charge"] or what EV owners are manually limiting their charge to)
  5. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    If their Level 2 charging station is reporting it used 14.7 kWh and charging efficiency is about 90%, the usable capacity of their battery is about 13 kWh.
  6. Roy2001
    371
    158
    Sacramento, CA
    Still, Clarity has less reserved capacity. And if count on loss, Prius would store only 5.5kWh on a 8.8kWh battery.
    But yes, Clarity has liquid cooled battery.
  7. triggerhappy007
    498
    334
    I wouldn't worry you much about capacity loss in a PHEV, you will always have a backup compared to an EV. I'm sure Toyota designed this car better than the Leaf. You won't lose half your range after three years.
  8. Llamaguy
    Llamaguy New Member
    Arkansas
    2018 Prius Prime
    I drove through the Honda lot when shopping and couldn't imagine seeing that eyesore every day. It positively makes the Gen 4 Prius look amazing in comparison.
