Question about the engine during deceleration
Discussion in 'Gen 2 Prius Technical Discussion' started by Bryan5, May 12, 2008.
  1. Bryan5
    Bryan5 New Member
    40
    MS
    Ok so when you're going less than 42 mph, and you let off the gas pedal, the fuel consumption meter instantly jumps up to 99.9 mpg, and the engine shuts off, right? So why is it that when I get closer to stopping (like less than 15 mph), the fuel consumption meter goes back down, and I can still hear the engine running? It still takes a few seconds for the engine to turn off when I come to a complete stop. Now this situation usually happens when I've been driving for less than 15 minutes, but it happens occasionally even after driving for several hours. I guess what I'm asking is, why does the consumption meter go up to 99.9 even though the engine is still running? Thanks!
  2. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    You'll get better responses with more real information, but I'll try to be the first to jump in.
    It appears you already know why this is happening more with the car in the first 15 minutes -- the ICE needs to warm up and it will not shut down (and stay down, as it were) until it has reached that prime operating temperature. You'll still see 99.9 mpg, because you are traveling a decent distance with exceptionally little gas being burned. You have no load in the ICE and no real drag on the engine. Sometimes you'll see the mpg show 99.2 or 96.4 or some such numbers. This again let's you know the ICE is running but you are not making any demands upon it.
    Why does it happen when you've been running for a long time? It could be that you continue to have other draws on power that require the ICE to run. Does it happen when your SOC is showing green bars and you have no electronics or climate control running? That would be a bit odd, I think. Still, I'll be coming back to this thread to read the better technical responses.
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Pearl often takes 5 or so seconds to shut down when she could do so immediately. It appears this delay is built into the software. Other times she shuts down the ICE as soon as I start slowing for a red light. Neither time is the delay for "ICE temp/cat initial warmup", though without a cat temp meter it's possible it was cooling off, though unlikely as the engine was running for some time before (it appears to take only about a minute to warm up a completely cold cat converter).
    So it looks to me there are two situations where shutdown works differently. I'd like a button to tell the car we'll be stopped for the first one. It's embarrassing sitting there for the 5 seconds with the engine running. ;)
  4. PA Prius
    PA Prius Active Member
    754
    241
    SE Pennsylvania
    My ScanGuage shows that I can be getting up to 240 mpg with the ICE still running. So yours is likely running in the situation you describe when it is showing 99.9 mpg.
    I too am perplexed at times when the battery shows a decent charge and the water temperature is 180°+ and I can't get the ICE to shut down by backing off and "feathering" the gas pedal.
    PA P
  5. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Bryan5,
    Toyota technical data says that the ICE must be running when the ECU does a
    purge cycle of the HC vapor retaining cannister in the fuel system. As the
    canister holds HC vapors generated during startup and shortly there after, I
    suspect that some of the ICE run-time during and shortly after warmup is to
    accomodate this purge.
    The technical data also says that the ECU periodically -- period, frequency and
    duration, not specified -- initiates pulling a vacuum on the space between the
    hard-case fuel tank and enclosed bladder to see if there is a leak in the
    bladder. Again, the ICE must be running. It is possible then that some of the
    apparently unnecessary ICE running after warmup may be from this test.
  6. Bryan5
    Bryan5 New Member
    40
    MS
    Thanks everyone for the quick replies. I thought I understood why the consumption showed 99.9 after reading the first three responses but then Rokeby's reply threw me for a loop hahaha. Maybe someone can dumb that post down for me? Haha thanks again everyone.
  7. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Bryan5,
    I am only-just-out-of-Newbie-dom, just went past 5K mi. I too am still learning
    what makes my Amapola tick. Believe me, I'm trying to be helpful.
    My earlier post is the dumbed down version!
    To see obfuscation at its finest -- the full Toyota Tech version -- go here:
    http://www.autoshop101.com/forms/Hybrid13.pdf
    Oops, this might be helpful too:
    HC = Hydro Carbon; petroleum, gasoline
    ICE = "Infernal" Combustion Engine
    ECU = Engine Control Unit (?), one of 6, or 8, or 13 computers in the Prius
    Cheers!
  8. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
  9. ryanmorley
    ryanmorley Junior Member
    22
    My prius was delivered with a cracked fuel tank. The first trip to the dealer they reset the check engine light at about 150 miles. At 300 miles the light came back on and I brought it in for smoke tests to find the source of the leak. I scheduled the repair for a week later... in that week I drove several hundred more miles and the check engine light came on around 450 miles.
    This leads me to believe that the frequency is every 100-150 miles that it does the leak-checking procedure you mentioned.
  10. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Thank you for that tidbit of information, the tech data is silent on this point.
