Question about the Prime Headlight Brightness
Discussion in 'Prime Main Forum (2017-2022)' started by top40, Dec 6, 2016.
  1. top40
    top40 Junior Member
    25
    Murrieta, California
    Does anyone find the Prius Prime front headlight brightness a bit much? Seems like it's really, really bright which I'm sure anyone driving ahead of me won't be too pleased about.
    And by the way, yes, I made sure that my brights weren't on.
    Let me know your thoughts. Wish there was something I could do about it.
    top40
    priuscatprimeguy likes this.
    49,397
    make sure they are aimed properly, toyota doesn't do a good job of that at the factory.
  3. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    I love the brightness. I am impressed by its sharp and horizontal upper edge of the illuminated zone. Because of it, I do not think a driver in front of me would notice the brightness. Ever if it may bother some, I would take this over my LEAF's head lights with which I see my own car's shadow when a car is behind me at night.
    ruby and giora like this.
  4. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    No issue at all at Bay Area in a bumper to bumper traffic. I even tried the auto head light beam up option on my way home. The high beam is vey bright and I think it's definitely dangerous to other driver. So I turned it off for good. Low beam is more than enough and is perfect for normal night time driving.
    iPhone ?
  5. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    Shouldn't be dangerous to other drivers if no other drivers are ahead of you,which should be the only situation to turn them on .
    What about distance of the high beam ?
    How far can you see ?
    High beams in gen 3. are great,even though they are only halogen,I am hoping for similar performance.
  6. Tideland2005
    Tideland2005 Member
    72
    34
    SoCal
    pattern...... it's all about the pattern.
    And, you can tell what the (low beam) pattern looks like and if the up/down, left/right
    adjustment is set correctly by the white wall reflection parked perpendicular,
    25' away, on level ground.
  7. yoyoman
    342
    117
    San Jose California
    The high beam is like a gigantic flash light beam up to the air.. its extremely bright.
    iPhone ?
    top40 likes this.
  8. top40
    top40 Junior Member
    25
    Yeah. The second headlight option feels like it's more than enough. The final option is pretty damn bright.
  9. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    Sharp cut off is fine when driving straight and level.
    But on bumpy, hilly and curving roads like in rural UK the bright zone frequently shines in the eyes of approaching motorists. Not good at all!
    bowang and jmarkd7 like this.
  10. ttait
    ttait Active Member
    273
    163
    Southern California
    Wish we could get the active headlights.
    Snow and Prius Maximus like this.
  11. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Sorry to glut the thread, but this is the -FIRST TIME- I have ever read someone wanting dimmer headlamps! ;)
    ruby, thatoneraccoon, giora and 3 others like this.
  12. vvillovv
    vvillovv Senior Member
    3,614
    1,272
    NY
    It's not just priui . The worst offender I've seen so far was a loaded Denali. Look up proximity sensor.
    If you see them coming at you, after they pass you, look in the rearview, if they have LED's on the tail they
    usually also have proximity sensors. Than you can count for yourselves how many of them actually work.
    A lot of drivers are also leaving their high beams on.
    I made my complaints known, now I'm working on looking away techniques.
    good luck
  13. jmarkd7
    jmarkd7 Member
    Virginia
    2018 Prius Prime
    I really dislike LED headlights, due to the instant cutoff from light to dark. As poster above mentioned, it's bad on hills. Have them on the prime was well as our 2014 Sienna XLE. Have thought about replacing them with halogen bulbs in the van. Don't even know if it's possible.
  14. Lee Jay
    Lee Jay Senior Member
    5,850
    4,023
    Westminster, Colorado
    That has less to do with the source of light than it does the optics.
    Insirt likes this.
  15. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    Exactly. (1) Keep the original type of bulb. The lens and reflector are made for it. It is illegal, unsafe, and inconsiderate to change the bulb type and often create a glare problem for other drivers.
    (2) The problems, if any, are due to aim or design. I agree, sometimes the sharp cut-off does not work out well. That part of the problem is design.
    (3) I wish the Prime did a better job of illuminating the sides where I want to see the turn into a dark side road or driveway.
    GT4Prius likes this.
  16. Tideland Prius
    16,128
    Some European cars still have cornering lights (lights that turn on when the steering wheel is turned left or right and point diagonally to illuminate the corner).
    I haven't seen an American car with cornering lights since the early 2000s.
  17. civicdriver06
    797
    324
    Germany
    On top of beeing able to drive with full high beam because upcoming vehicles and the ones ahead are automatically cut out of the beam the European "Prime" will have cornering lights because the adaptive headlight system also moves the beam in the direction you're steering .
    The system also adjusts the beam in 3 different levels to the speed you're going.
    Going faster means the beam will reach further ahead while in urban driving the headlights will especially illuminate the sidewalks so pedestrians can be more easily seen .
    It remains to be seen how well these new headlights will work !
    Toyota always seems to be a step behind their competitors when it comes to technology like this !
    #17 civicdriver06, Dec 13, 2016
    E-GINO, giora and Tideland Prius like this.
  18. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    By "automatically cut out of the beam" do you mean that the lights auto switch to dipped or low beam? That's my understanding of what they do.
  19. Lee Jay
    5,850
    4,023
    No, he's talking about so-called "matrix LED" headlights. Look it up. It's quite active.
    Prius Maximus likes this.
  20. Prius Maximus
    Prius Maximus Senior Member
    935
    780
    Northeastern IL
    Yeah, those matrix LEDs look impressive. Wish USDOT would get off their butts and approve them
