question about the tire pressure sensor
Discussion in 'Gen 2 Prius Main Forum' started by hybrid_batmobile, Dec 26, 2006.
  1. hybrid_batmobile
    hybrid_batmobile New Member
    I've had a little trouble with the sensor. It has gone off and i've filled it, but it hasn't gone off-- there isn't a hole in any of the tires. How do i turn it off or is there something with the sensor?
    thanks
  2. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
  3. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    <_< Howdy hybrid_batmobile
    Your Owner's Manual has a section on the TPWS. You need to reset the system with the button under the steering column after you have all four tires inflated to your desired pressures.
