Question about timer charging and email alerts.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Vulcanman, Jul 31, 2013.
  1. Vulcanman
    Vulcanman Junior Member
    68
    Anyone have a setup where they get email alerts when the charging is complete?
    Does this alert get sent even when you start the charging process manually?
    I don't get any emails even though website is setup to send me alerts.
    Just trying to troubleshoot. Thanks.
  2. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    I get an email from Entune when charging starts, ends, and if it is interrupted (disconnected prior to finishing). I also get one with a timer failure... when you set it, but forget to actually plug the car itself in (oops!).
  3. Vulcanman
    68
    So those "charge complete" alerts are sent even without use of the timer?
  4. Vulcanman
    68
    Duplicate post Deleted
  5. TonyQ
    TonyQ Junior Member
    16
    2013 Prius Plug-in
    Yes, charge complete email is sent even if you're not using the timer.
  6. Vulcanman
    68
    Thank you.
  7. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :confused:Received a email yesterday stating that charging had been interrupted. Still had a full charge. Not sure what happened.
  8. uropip
    uropip Member
    138
    38
    S.E. MASS
    2013 Prius Plug-in
    This is only on "Advanced " model right?
    poopy! lol
  9. retired4999
    2,652
    625
    Eau Claire, Wi.
    Correct!
  10. CharlesH
    2,796
    1,163
    Roseville, CA
    Only the Advanced has the built-in Safety Connect cell phone which is used to send these reports. You can set which events you want to get e-mail about on the Entune Web site.
  11. Vulcanman
    68
    Eureka!
    They replaced the Digital Communications Module in my car.
    It's working now.
    lensovet and john1701a like this.
