question about US radio frequencies
Discussion in 'Gen 2 Prius Audio and Electronics' started by gania13, Aug 11, 2011.
  1. gania13
    gania13 New Member
    Israel
    hi guys,
    i live in israel, and we have european frequencies, with even numbers.
    for e.g. 107.00Mhz.
    i heard that US radios can't play even numbers, so it can only reach it colesly, like 106.90 and 107.10.
    i want to buy an original prius radio from ebay, and probably it will be from the united states,
    so my question is, will i have problems listening to radio?
  2. Politburo
    Politburo Active Member
    971
    208
    If you get a US radio, yes, you will have problems.
  3. gania13
    gania13 New Member
    Israel
    is there a way to fix it somehow?
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    That's weird. My UK radio goes up in segments; 97.00, 97.05, 97.10, 97.15 etc.
    I've heard some Japanese fm radio's done have the full 87mhz - 108mhz coverage in that they miss some entire sections of the frequency.
    I never knew something as simple as fm radio could be so complicated around the world.
  5. Politburo
    971
    208
    The only way to fix it would be to use a EU OEM radio or an aftermarket unit that supports EU frequencies.
  6. jdenenberg
    jdenenberg EE Professor
    3,932
    1,932
    Trumbull, CT
    2020 Prius
    LE AWD-e
    In the US stereo FM stations are at:
    88.1, 88.3, 88.5, 88.7, 88.9, ... 107.9
    JeffD
  7. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    What was the original reason for the odd/even frequencies?
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The JDM FM band is 76-90 MHz. I have a couple of portable radios that cover 76-108 MHz to cover all options.
    @ the OP
    I have seen portable radios with a hidden switch for North America/Europe center frequencies and with secret keyboard combinations to switch them but not car radios.
  9. Politburo
    971
    208
    I once had an aftermarket unit with a switch in the back. They probably don't make them like that anymore, but I do not know for sure.
    I don't think there is a real reason behind it. It's just how things developed.
  10. gania13
    gania13 New Member
    Israel
    too bad...
    ok guys thanks for the help everyone
  11. jdenenberg
    3,932
    1,932
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Monaural FM requires half the bandwidth and was originally allocated every 100 kHz. A Stereo broadcast needs extra bandwidth so every other 100kHz is skipped.
    JeffD
    Inventor of the Phase-Locked-Loop based FM Stereo Demodulator in your radios
    4 people like this.
  12. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Cool! Thank you for that bit of clever engineering.
    Tom
  13. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Jeffery, very nice resume, and yes thanks for the decoder. I have enjoyed the efforts of your work for years. I remember when Stereo FM was new to me in '71...... My first Chief Engineer job at a small college FM station. Fun days those!!!
