Question: can one bad battery blade prevent the HV from charging
Discussion in 'Gen 2 Prius Technical Discussion' started by Joseph Li, Jun 9, 2023.
Tags:
  1. Joseph Li
    Joseph Li Junior Member
    Pittsburgh
    I recently got the P0A80 code and Dr. Prius shows a bad battery in bank 5. I figure I could still drive it until I get the replacement battery, but after driving for a bit, the Energy Monitor on the dash was indicating that HV battery wasn't charging and I suddenly lost power when trying to accelerate.
    Any information on why this happened?
    Thanks
    Meg&Bear likes this.
  2. Tombukt2
    Tombukt2 Senior Member
    12,221
    2,157
    Durham NC
    Well if energy is not flowing across all the blades and not being accepted by all of those said blades modules and pins here we are so I guess you can't drive it so you're figuring was okay until it wasn't but yeah the thing is all in series these cells modules whatever you want to call them so when it runs the energy runs up on something that it doesn't like it stops moving gets held up by resistance ohm's law and all that and then you have a mess.
    51,157
    if it's bad enough, the whole battery is affected
  4. dolj
    dolj Senior Member
    8,217
    4,188
    Wellington, New Zealand
    It gets better than that, just one cell of the 168 in the battery can take the battery out. The car will protect the battery when it detects a cell failure.
    Meg&Bear and Tombukt2 like this.
  5. pasadena_commut
    pasadena_commut Senior Member
    2,284
    681
    Southern California
    Prius battery packs consist of electrical devices in series. The cells are in series within the blades, the blades are in series within the pack. Any complete failure along that path takes the whole thing out. It isn't just the cells, if any of the connectors between the blades fails that is all she wrote. In fact, that is pretty much what the battery disconnect switch does.
  6. BiomedO1
    BiomedO1 Senior Member
    2,826
    1,500
    SacTown, Ca
    The traction battery management CPU disabled the charging function to protect the electronics. If you hook-up a Toyota scan tool; it'll tell you what parameter was violated, that cause the shut-down.
    Hope this helps....
