Question: Engine lubrication
Discussion in 'Gen 2 Prius Technical Discussion' started by garyquicker, Oct 14, 2010.
  1. garyquicker
    garyquicker New Member
    Edmond Oklahoma
    Does the engine turning on and off frequently lead to a lower engine life? I have always heard that the biggest wear on an engine happens when it is turned on.
    If the oil is draining from the Prius engine each time is stops it seems like there would be a lot of engine wear.
    Does the Prius (2010) engine have some way of keeping the engine lubricated when it is turned off?
  2. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
    The Prius engine in normal driving is not off long enough for all the oil to drain, and the surfaces to loose lubrication. The engine is also warm. The wear occurs when starting a cold engine that has not had the oil flowing for hours, so there is not as much of a oil film left on the surfaces.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The Prius starts its engine differently than normal cars. The engine is spun up by a large electric motor (MG1) to a fairly good speed before gas and spark is applied. Only after the oil pressure comes up does the engine begin to fire.
    Tom
  4. vertex
    670
    143
    new york
    2018 Prius Prime
    Good point. I see a few PCrs have gone over 300,000 miles, so the engines seem to be very low wear.
  5. jdenenberg
    jdenenberg EE Professor
    3,850
    1,843
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The other factor is that the ICE is never subjected to rapid changes in torque. The Computers do very smooth changes (the cutoff of power when a wheel slips also protects the ICE). There are no rapid torque changes due to transmission shifting (eCVT) or user behavior.
    My 2004 Prius is at 183,000 miles and it's ICE is doing fine.
    JeffD
  6. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Isn't there always a thin film of oil on the surfaces that will never "drain" or dry out no matter how long the engine is stopped?
  7. uart
    uart Senior Member
    4,215
    1,200
    Australia
    It wont go completely dry but the oil does gradually creep away.
    To the OP. I thought the same thing when I first got the Prius, that all the stopping and starting of the engine must be bad for it, but now i think it's probably easier on the engine than most cars. The reasons are.
    - Apart from the first one they're all warm starts with plenty of oil already in the bearings.
    - As Qbee42 said, the Prius starts the engine in a different way to other cars, the engine is spun relatively quickly but at no load before fuel and ignition is applied. Even on the first cold start you're probably getting oil pressure before any load or ignition is applied.
    - Also at cold starts the Prius really seems look after the engine by preferentially drawing power from the battery. This means that as long as you drive easy for the first minute or so then it just lets the engine warm up under almost no load.
    Not surprisingly worn out engines are close to an unheard of problem around here. :)
  8. pEEf
    pEEf Engineer - EV nut
    720
    577
    Berkeley, CA
    Here's the only thing bad I've ever seen happen to the Prius Engine:
