Question for all
Discussion in 'Prime Main Forum (2017-2022)' started by Jonathon Hyde, Jul 24, 2021.
  1. Jonathon Hyde
    Jonathon Hyde New Member
    2018 Prius Prime
    Hello All! I am brand new owner of a used 37K 2018 Prius Prime advanced in blue. My simple question to you all is, what have you bought, added, or modified on your Prius Prime that added the most value or utility? Also, I am not hearing the terrible beeping everyone refers to in reverse mode. Am I lucky and the previous owner had it cut off or what?
  2. Tideland Prius
    16,621
    Not sure about most value since everyone’s tastes are different but a set of 17” or 18” rims usually completes the look. I find the Prime’s design is sporty enough to warrant larger rims. However, you will lose EV range due to the larger rims.
    Some people have added roof boxes for added utility when travelling with a full car.
    Yeah it’s likely the previous owner changed it to a single beep and the car wasn’t factory reset before it was sold to you. You may want to reset the nav to factory settings (to remove the phone and favourites) then customise it to your liking. The Homelink garage settings likely needs to be deleted.
    But I’d retain the other car settings (like your reverse beep) since it requires the dealer to set it.
  3. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    I have not added anything.
    The previous owner had the beeps turned off. So did we.
    MTN likes this.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    I do addition by a deletion on my current 2021 PP Ltd. I just deleted Softex seats I hate so much. To Do list on my third Prius Prime | Page 2 | PriusChat.
    I plan to delete the piano-black interior by wrapping. If I could, I would delete the 11.6" display, but there is no good solution for that, so for now, I have it just turned off. I may try deleting the VPNS sound (aka spaceship sound) later, but this is not a problem on the 2018 PP.
    MTN likes this.
  5. Trollbait
    12,687
    Spare tire seems popular depending on where you roam.
    pghyndman likes this.
  6. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
  7. Trollbait
    12,687
    Just reminded me of a Prius I saw earlier this week. An older white one that actually had a set of bull horns on the front of the hood.
    Jonathon Hyde likes this.
  8. dtsexpert
    dtsexpert Member
    179
    83
    San Francisco
    not add value to the car but I replace all the interior light to LED.
    Tint the window if you have not done so.
    I also have 12v pump, 12v impact wrench and an tire plug kit in case I get the flat tire.
  9. Washingtonian
    Washingtonian Senior Member
    726
    621
    If my wheel lug nuts were so tight that I needed an impact wrench to remove them I would loosen them at home first to avoid carrying that tool. I removed the wheel covers and bought a set of covers for the center part as I thought the plastic wheel covers were not attractive.
  10. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
    Adding LED strip lighting to the trunk is a nice addition since the stock trunk bulb is pretty dim.
    And kitting up a tire patch kit as others have noted is a good idea as well.
  11. JMalmsteen
    JMalmsteen I love my Prius!
    287
    266
    Long Island, NY/Lancaster, PA
    I bought different rims, black ones like the ones on our WRX. I've gotten 76 mpg without plugging the car in, so I don't think changing then affected the gas mileage. We also keep a full size spare in the car.
  12. Trollbait
    12,687
    With wheels, it depends on their weight whether it hurts fuel economy. Most wheels that are a larger diameter ones tend to be heavier than the factory. Increased weight at the wheel is the worst place to add it in terms of efficiency. The wider tires on such also don't help.
  13. eatriceyo
    eatriceyo Member
    45
    33
    Honolulu
    first thing to do is tinting the windows if not done so already, makes a big difference in cabin temperature and get a full front windshield tint if your city allows.
    changed all interior, trunk, and reverse lights to leds since it looks nicer.
    i also got a reusable k&n cabin air filter and just wash and refresh it whenever i do my oil change.
  14. PT Guy
    PT Guy Senior Member
    1,085
    712
    Washington, the state
    Jonathan, there's not much to add except to suit your needs. We have rubber floor mats to catch out mess. I chose to put on run-flat tires. Some carry a compact or full sized spare; be sure to strap it down securely to avoid having an unguided missile inside the car if someone hits you. The spare off a Corolla fits. The Bridgestone DriveGuard 3rd generation run flats are substantially heavier than the original low rolling resistance tires, but I don't notice a significant hit to battery endurance nor gas consumption. The DriveGuards are a bit noisier & harsher riding than original, and said to be good for 50 miles at 50 mph deflated...then they're junk. If promptly driven to a tire shop for repair they're likely reusable. The original low rolling resistance Toyos were vary light weight due to the thin casing, and a tiny screw put in a surprisingly large hole.
    "The wider tires on such also don't help."
    It's a mixed bag. Given that a tire's total footprint area is about the same for the same weight on it and the same inflation pressure, the wider tire will have a shorter front-back footprint and wider side-side dimension. The means less deformation of the tire than a narrow tire with the longer front-back measurement, so the wider tire will have slightly less rolling resistance. The wider tire will have more air resistance, but that's usually less than the gain from less deformation.
    "If my wheel lug nuts were so tight that I needed an impact wrench to remove them I would loosen them at home first...."
    Loosen, then tighten to 76 lbs-ft.
  15. OkaneOshima
    OkaneOshima Junior Member
    Utah
    2019 Prius Prime
    One modification here: removed the fugly hubcaps and added center caps to the stock alloy wheels underneath. It makes the car look 100% better, with extremely minimal impact on fuel economy.
