Question for Experienced Welders
Discussion in 'Gen 2 Prius Accessories & Modifications' started by cycledrum, May 22, 2009.
  1. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Would 'TIG welding with stainless steel rod' be the best method for welding to the seat rail shown below? Or would MIG with flux core wire be just fine?
    I ask because Solar_Powered mentioned using TIG when welding the same pieces. Didn't get a PM back from SP recently.
    The weld has to be in the crevasse in the pic. I would sand off paint first. (this is a Corolla 'foot' just for example).
    Here's the front extender brace tack welded
    Glad I'm trying this on a used seat.
  2. Daox
    Daox Member
    196
    58
    US, Wisconsin
    Tig or mig will work. Tig would likely be prettier if you know how to tig weld. Flux core is messy, but it'll do the job. I believe that is just a mild steel bracket, so theres no real reason to use stainless filler rod, but you can if you really want to.
  3. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Thanks for the reply!
    Booked a MIG and helmet to rent this weekend. The agent reminded that TIG welders are very expensive and said even he couldn't get the hang of it.
    They'll give me scrap metal for practice. Planning to weld in the backyard.
  4. msirach
    msirach Member
    321
    Southern Illinois
    I second the words of Daox. No need for stainless and I would recommend tig if available. Flux core wire if you are doing it yourself. (with a 4" grinder available.)
  5. dogfriend
    7,512
    1,189
    Carmichael, CA
    I'm not a welder, but a mechanical engineer with a bunch of grad work in material science. Ideally, you would use filler rod that matches the base material as closely as possible. I agree that the rails and brackets are mild steel - no need to use stainless steel filler.
  6. dogfriend
    7,512
    1,189
    Carmichael, CA
    I took a welding class back in college. We had one day to try TIG welding. It was really easy to blow a hole in whatever you were welding.
  7. Daox
    Daox Member
    196
    58
    US, Wisconsin
    I'd also recommend taping off the rails where you don't want spatter to get into. It can sometimes be a pain to chip off and if you can't get it out, it may bind up with the mating part.
  8. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Thanks for that.
    Not too expensive to rent. About $70 / day.
    Thanks again Daox. Also msirach thanks.
    Off to work.
