Question for the Gurus, name that Part
Discussion in 'Gen 3 Prius Technical Discussion' started by Michael Mann, Oct 26, 2019.
  1. Michael Mann
    Michael Mann Active Member
    167
    408
    Bay Area, CA
    Looking to order this brake master pump and the top part number is easily accessible but what is the significance of the highlighted number? I see nothing that matches that number. TIA
  2. Elektroingenieur
    2,515
    3,287
    Three Touring
    Neither number seen in your photo is the service part number for the brake booster with master cylinder assembly on a 2010 Prius, which is either 47050-47140 (15-inch wheels) or 47050-47150 (17-inch wheels); see catalog Figure 47-02, Brake Master Cylinder.
    For Customer Support Program ZJB, which expires at the end of next month (November 2019), there are special part numbers, 04002-33347 or 04002-33447, respectively, listed in bulletin T-SB-0079-18.
    On the part in your photo, I imagine 47270-47030 is the production part number for the assembly or one of its components, and the other number is a serial number or date code. I’m not sure I’d buy a part advertised as “47270-47030,” since there is no way to tell whether the software in the skid control ECU (part of the assembly) is the correct version for your car.
    Tande likes this.
