Question for those who moved gen3 to gen4
Discussion in 'Gen 4 Prius Main Forum' started by Joaquim Silva, Aug 19, 2017.
  1. Joaquim Silva
    Joaquim Silva Junior Member
    31
    30
    Lake Havasu City AZ
    I am curious about your likes and dislikes of gen 4 if you moved from gen 3. We all know about the fuel economy but I am curious about your own take and not the take/hype by professional media.
  2. ea8631
    ea8631 Member
    186
    Toronto, Ontario
    Technology
    So far there is a few things I found after I own a gen 4 for a week:
    1. Lag of storage space (really miss the second glove box and the space under the shifter in gen 3)
    2. No remote a/c on gen 4.
    3. The Windows didn't have the "soft closing" effect on gen 4 as gen 3 have. Seems like the gen 4 window can chop something off when closing (haha just kidding).
    4. Overall the materials feel like is cheaper. Example : plastic covered sun visor and hard surface on the interior a & b pillar cover and rear seat belt area vs gen 3 all of them are covered by cloth or softex.
    5. No JBL in Canadian market. (Good thing the stock radio still ok in gen 4).
    6. Seems like gen 4 do abit more quiet compare to gen 3.
    7. Gen 4 seems like avoid using engine as much as possible. For my old gen 3 the engine will start up during the first time in the day no matter what temperature outside is but so far the gen 4 didn't during the week I own.
    8. The softex seems like softer compare to my old gen 3.
    9. The head room (on the driver seat) feel like a lot more compare to gen 3.
    10. Like the led headlights so far, hopefully it won't become yellow and haze as my gen 3 did during the 3 year I own it.
    #2 ea8631, Aug 19, 2017
    Mambo Dave and RCO like this.
  3. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Gen 4 is like a totally different car, it has more power, Gen 4 ECO mode is like NORMAL mode on Gen 3, it handles and corners better. There is more height adjustment on the driver's seat, the displays are in colour and there is more info. There are lots more safety features, the cruise control is now adaptive cruise, the headlights are LED as standard, the park assist (where fitted) is much improved and lMO it looks much sleeker and more modern.
  4. Tideland Prius
    16,195
    My background... 2010 Prius w/ Technology Package (kind of like a US Prius IV w/ AT package.. which doesn't exist for you guys) vs. 2016 Prius w/ Touring Package (similar to a Prius Three Touring)
    Pros
    • Quieter (mostly tire noise so on concrete, it's noisy but on fresh asphalt, it's Lexus quiet)
    • Better comfort (rear doesn't skip/bounce over uneven road due to the new independent rear suspension. Keep in mind I have the 17" wheels. It'll be more comfortable with 15")
    • Better handling (lower centre of gravity and better suspension tuning = flatter cornering. Around on/off ramps, you don't lean into your seat bolsters like you would in the Gen 3)
    • Comfortable and supportive (to me) front seats
    • More front passenger headroom (the front passenger seat in the Gen 3 is mounted quite high)
    • Lower front seats = more headroom
    • TSS-P (full-range DRCC is awesome. My DRCC only works down to 25mph)
    • Bi-LED headlights (Very bright clean light at night)
    • All LED exterior lights except for turn signals and reverse light
    • Soft touch upper door trim (that's on higher trims. Base One, Two and Two Eco will have hard plastic. Keep that in mind)
    • Supposedly nicer headliner material... similar to my friend's TSX. To be honest, it's doesn't feel *that* much nicer than the regular mousefur. Tell me when it's plush cloth or alcantara)
    • Waaaay better mpg. It's insane
    • Stays in EV more often. The torque curve is such that it feels sprightlier at lower speeds (but the 0-60 remains the same)
    • 12V outlet in the rear seating area (really the total # of 12V outlets is the same - they just moved one of them to the rear so now you only have one in the front)
    • Front cupholders finally have grips for different sized drinks. (On the downside, it's the first Prius to have exposed front cupholders. All before Gen 4 have covered or hidden cupholders)
    • Finally have grocery bag hooks in the cargo area
    • Twin 4.2" full colour MIDs are very sharp and clear (vs. the VFD monochrome on my 2010... Colour was added for 2012)
    • While I prefer a leather-wrapped steering, the SofTex material allows for thermal control so it's not as cold in the winter and not as hot in the summer. In 41°F temps, the leather-wrapped wheel in my Gen 3 was cold to the touch while on the Gen 4, I could hold it comfortably.
    • Touring models have contrasting blue stitching in the seats and blue trim around the vents - nice touch
    • Heated front seats are now dual-stage (not on our Touring but those models that have it....)
    Cons
    • Removal of upper glovebox
    • Replaces under-bridge storage with an open tray (with or without Qi wireless charging depending on model)
    • A & B pillar on my Technology model were covered in felt and looked more expensive than regular hard plastic. Gen 4 (all models) have cloth-covered A-pillar but the B pillar is hard plastic
    • More hard plastic in the rear seating area - the wheel well area used to be covered in upholstery (vinyl in my Gen 3 b/c I have the leather interior) but now it's hard plastic.
    • Resin door inserts (used to be cloth or vinyl on the Gen 3 depending on whether you had the cloth or leather interior)
    • Centre console box opens sideways - a bit annoying if you're the front passenger
    • Removal of underfloor bin in cargo area
    • One low power USB port (really?? couldn't have a second one inside the centre console?)
    • Rear seat seems a bit more upright than Gen 3 but it does gain a smidge of headroom (enough for me to fit under vs. Gen 3 where I'm hitting the ceiling. They just moved the cut out in the ceiling)
    • Steering wheel switches are plastic (and a little loose feeling). Gen 3 had soft-touch buttons for the most commonly used buttons
    • Loss of climate control buttons on the steering wheel
    • Glare from the 7" MFD. (They went with a glossy finish for Gen 4 vs. matte on my Gen 3 with navigation)
    • No leather option (just cloth or softex. My Gen 3 had perforated leather... but upholstery is a personal choice)
    • I don't know if it's the camera or the screen but the backup camera doesn't seem to be as clear as the one in my Gen 3. It's fine during the day but I feel my Gen 3 is clearer at night.
    • Also, the position of the rear camera (centre in the Gen 4 vs. driver's side in the Gen 3) means the camera seems to get water droplets on it more often than in my Gen 3 which makes it useless when you're reversing and can't see because a water droplet is covering the lens.
    • The windows no longer have the variable-speed function that allowed for soft-closing in the rear windows.
    Neither here nor there
    • No solar roof option (but I know why it was offered in the Gen 3.... the updated version is now on the Prime but the ventilation feature is really nice. )
    • No water-repellent front window glass
    • Acoustic front door glass is available in higher trim levels (but not on our Touring). Acoustic windshield is standard on the Gen 4 as before
    • With TNGA, it means more shared parts. Given the size of the Prius, that means it'll be sharing parts with the Corolla so compromises will be made. Either the parts get improved in the Corolla or parts in the Prius get downgraded (at least those that were improved or better in the Prius to justify its higher price). That may explain the change in backup camera quality (I found the 2014 Corolla's camera to be crap at night with too much noise)
  5. liquidtenmillion
    liquidtenmillion Active Member
    261
    194
    Easley, SC
    I come from a 2015 3 which I was overall impressed with, here is what I think:
    Improved in 2017(3 touring with lithium ion battery):
    • Car handles better, you can go around corners without having your body thrown around as much, high speed cornering is not as scary
    • Car has faster acceleration
    • The braking has improved
    • It feels indistinguishable just about from a normal car now in all driving situations
    • Much more comfortable and supportive seats
    • On acceleration if you press the gas pedal past the "eco line" on the hybrid system indicator it doesn't immediately turn the engine on, sometimes you can accelerate straight into the pwr area without turning the engine on, even if not in EV mode.(don't know if this is lithium models only or all)
    • The TSS-P is standard, so you get DRCC, PCS, lane departure alert, automatic high beams etc. All good stuff.
    • Touchscreen is higher quality, the interface is much faster.
    • MUCH better mileage, far bigger difference than the EPA numbers indicate. In my 2015 I would get 42mpg if I was driving hard and fast, and approximately 48mpg driving as economically as possible(I have a ton of mountains, lots of extremely poorly timed red lights, speeds of 80mph, etc.). With the 2017 I get 50mpg when I am driving as hard as possible at 80mph, and can exceed 70mpg on 40 mile round trips driving economically on good flat roads. It is substantially improved.
    • Steering wheel is perfectly round now, and maybe larger too(I forgot about this one)
    • The seats will adjust much higher/lower than before, way more adjustable.
    • The little triangle window is useful now, you can actually look through it and it helps visibility(they eliminated the arch thing that blocks a good chunk of it)
    • No forced engine warm up if the temperature is at least 80ish F, which is basically every day where I live.
    • Can program windows to roll down when you hold the unlock button on the fob
    • Way less rattles and noise, on my 2015 I had no less than 6 different things that constantly rattled that took about 6 months to trace and stop with pieces of felt.
    • Lots of soft touch plastic, you can press into the plastic on the dashboard and the door, they feel soft to the touch and slightly squishy, the 2015 all the plastics were bone hard and prone to rattles and felt cheap.
    Downgraded in 2017
    • No under-hatch storage bin
    • only 1 glove box
    • Much less storage in the front of the car, no bin under the flying buttress, the space has just disappeared somehow
    • Backup camera worse at night
    • Somehow even LESS rear visibility.
    • Rides about 1 inch lower, a lot more likely to scrape
    • USB port is now outside the glove box, may be a pro to you, but I plug an iPod into it and then hide it in the console and never touch it again. Everyone who walks past my car knows I have some type of media device plugged in and ripe for the taking.
    • No 12 volt on the dash, could get in the way of windshield mount accessories.
    Things that were bad and still not corrected:
    • Steering wheel still doesn't come out far enough, I would kill for an extra inch.
    Mambo Dave and kithmo like this.
  6. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Apart from me, who wouldn't?
    kithmo likes this.
  7. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    We purchased a Prime Advanced this week ($28k) (our Gen 3 Prius was destroyed in a head-on collision by a woman driving to the left of the double yellow line) via CostCo and the dealer in Auburn CA. The reviews herein are spot-on. The vehicle is quiet and handles very well. Toyota has done itself proud.
    pilotgrrl likes this.
  8. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Definitely, maybe even two :unsure:
    Mendel Leisk and RCO like this.
  9. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    As long as you don't go the whole handful! :eek:
  10. Chad's Dad
    Chad's Dad Junior Member
    35
    Austintown, OH
    Traded my 13 for a 17, and still have the 10...
    A week and a half in, and I must say that everybody has answered accurately. I would add that the sight lines are very much improved in the G4. You can see the road closer in front of you, and your vision when making a turn is much better. I noticed that a half mile into my test drive. The ride is much better as well. The technology in the G4 amazes me, and the heads up display is worth every penny. Much, MUCH safer to be looking at it on the road in front of you, instead of looking at it in the middle of the car. I have watched that for 7 years and look at it religiously.
    I still have a lot to learn about the 17, but I absolutely love it. Oh yeah, the mileage. The best I ever coaxed out of the 10 was 59.9 according to the display, and 57.3 out of the 13. First tank so far in the 17 is 62.6 and that's driving back and forth to work. I also like that the G4 has the setting for your mileage for each trip, with a fresh start every time you start the car, where the 13 told you at the end of your trip, nothing on the 10. My wife wants to challenge me on driving scores.
    Driving position, wasn't a fan of it in the G3. My left arm, my elbow would have to sit very uncomfortably on the top of the door when I held the wheel with that hand. The right arm, elbow sat on the center compartment. So the left elbow was high and the right one was low. In the G4, the left arm and elbow sit comfortable on the arm rest, making them both near the same level. Made two trips in the 13 from Ohio to Illinois this year, and it drove me crazy. Can't wait to make a long trip in the 17.
    My only cons would be the lack of the upper glove compartment and the storage. That being said, however, I like the bridge being gone. The bridge gave driving that car a kind of a closed in look, like a cockpit. I prefer it being more open. The junk that I had under the bridge was just junk anyway.
    pilotgrrl, Prodigyplace and RCO like this.
  11. Mendel Leisk
    38,873
    You dislike the centre bridge because you filled it with junk, lol?
  12. mariposer
    mariposer Junior Member
    33
    17
    Hot Springs Village, AR
    Three Touring
    Initial reactions after 3 days are
    I love the ride
    mpg greatly improved
    miss the storage space
    cup holder is weak
    I have difficulty exiting the vehicle
  13. wcurry
    wcurry New Member
    weare, nh
    full disclosure.. going from a 2011 with 135k miles (and one accident).. to a 2017 with 5 miles on it when i got it, so some differences may be due to wear and tear
    Also, I went from a 3 (with solar sun roof) to 4 with advanced technology package
    this is my 3rd prius.. i can't imagine having anything else. that said..
    pros:
    • automatic wipers
    • can set climate control to be only in front (when no passengers in back)
    • handing is MUCH better - especially on corners
    • i love the heads up display
    • en tune integration with pandora/slacker/i heart radio
    • a bazillion safety bells and whistles
    • cruise control will slow you down when it gets too close to car in front
    • heated seats
    • end of trip mileage report (when i shut off the car if gives me a report on that trip's mileage, air conditioning, etc)
    • backup camera is clearer and comes with the "warning.. too damn close line
    • power plug in back row (no more long power cables)
    • mileage (thus far) is much better
    • it feels like i'm sitting higher and have better range of site up front.. but it might be that the automatic seat is set higher
    cons:
    • less glove box space
    • less space under back hatch
    • no spare tire (patch kit.. )
    • lost solar option (which purportedly cooled car when parked on hot days)
    nits (aka first world problems):
    • map update is on card (not dvd); but the update is ridiculously overpriced
    • entune does not have WAZE/Amazon Music/Android Auto integration
    • the qi phone charger isn't very powerful. i'm still better off plugging in my phone
    • there's a weird sound (like remote sirens very faint) when decelerating.
    krmcg and Mendel Leisk like this.
  14. Wraiththe
    Wraiththe Member
    263
    49
    Charlotte NC
    Has anyone modded a way to get more storage space?
  15. MalachyNG
    MalachyNG Active Member
    300
    222
    Northern NY
    2022 Prius Prime
    There's really thick foam in the spare tire well. If you didn't get a spare you can go nuts on that foam with a jigsaw and add your own storage cubbies (you may get more road noise by doing so). There really isn't any extra room under the front seats. There's a small gap between the wireless phone charger and the plastic under the shifter. You could probably rig a little shelf or net to catch stuff that falls off the charger shelf area
  16. Wraiththe
    Wraiththe Member
    263
    49
    Charlotte NC
    Looks like I will just have to learn to go commando.
    Baaaahahahahaha
    MalachyNG likes this.
  17. orangecones
    orangecones Member
    46
    28
    NZ
    My reference points are a 2014 US-spec Two and a 2016 JDM-spec A (similar to a US Three). I admit that in the Gen 3, I'm kinda sucker for the flying buttress center console design and I miss that in the Gen 4. On the flip side, the smaller center console in the 4 does make for an arier-feeling cabin, at least in the models with the white trim pieces, the all-black interior versions still feel claustrophobic. Cabin materials I also found to be a mixed bag - some are clearly nicer on the 4, others were nicer on the 3, although I do believe even the "less nice" 4 materials are still more durable long term. Overall I still find the cabin a pleasant place to be, with generally good ergo (I don't have heated seats with their dumb switch placement). At least in the front - I haven't spent any time in my 4's rear seat. Seat comfort is about the same. Bit more headroom (and height-adjustable seats) do make me happier as a taller dude. I don't care about the missing upper glovebox. The cargo space in the back - can't say I've noticed much difference. I've done airport runs in the 3, and just last weekend I did some flat pack furniture in the 4 - and they all fit everything I needed.
    On the driving front - as some other folks pointed out, it's different, and better in the 4. The 4 definitely seems more shy about cranking the ICE, while the 3 would do it if you looked at it cock-eyed. Maybe the 4 is quicker, but real world driving, you got me fooled. The handling is much improved. Where the 3 can sometimes feel like you're driving a school bus, the 4 feels like a normal car. Don't be fooled, it's not a sports car by any means, independent rear or not, you're still very much in a Prius, but it's not bad, and it absorbs road imperfections about on par for the course, too. Could be due to difference in equipment levels (15" and FWD, vs 17" and eAWD) but no real MPG difference between the 3 and the 4 for me.
    What is nice about the 4? No head gasket drama.
  18. kc5dlo
    kc5dlo Active Member
    266
    163
    DFW TX
    2021 Prius
    I for one was surprised by the much better MPG. Overall very happy with the purchase.
    The other evening my wife drove the car for the first time. Took her forever to get going as she could not see the shift pattern on the shift knob. It's muscle memory for me but this was the first time for her after owning the car 11 months. The Gen 3 I had had the little LED on the headliner that put the shift knob in the spotlight. The 2021 still has the light but does nothing for illuminating the shifter.
  19. vvillovv
    vvillovv Senior Member
    3,747
    1,320
    NY
    I upgraded the 2014 PiP to 2017 Prime plus. It was a whole new game. Around double EV range, enough new gauges to bend the mind (so many I still don't get all of them), Basic Entertainment (Stereo) is not to shabby compared to older cars in it's class. 7" screen is good enough and the base (plus trim) has at least a few buttons to push and turn, instead of having it all on the bigger 11" touchscreen.
    Ride is A OK for me cause I don't need 17" wheels to look cool or tweak the handling or custom suspension stuff to lift the car or stiffen the ride. All around I'm satisfied with the Prime for the past 4 years and still learning new stuff about how the different driving modes work in all 4 seasons.
    #19 vvillovv, Dec 13, 2021
    Tideland Prius and kc5dlo like this.
  20. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Maybe the light needs adjusting - mine is clear as daylight.
