Question from a New 2021 Prius Prime Owner
Discussion in 'Prime Main Forum (2017-2022)' started by HanS0lo, Apr 20, 2021.
  1. HanS0lo
    HanS0lo Junior Member
    WA
    First time PHEV owner, took advantage of the recent rebate, just bought the LE trim yesterday. Love it! Question:
    1. can I leave it plug after it is fully charged? Would it damage the battery? I assume it is smart enough to balance itself out.
    2. I will start travel internationally after things settle down, what is the best way to keep all batteries (12v, the traction) healthy? Can I leave them plugged?
    3. What kind of roof rack do you recommend?
  2. Tideland Prius
    16,445
    Congrats and welcome to PriusChat!
    1. Yes but it’s not preferred since it takes a bit of charge from the 12V battery.
    2. In this case, no. Don’t leave it plugged in while you’re away cause you may drain the 12V battery. Also, Toyota recommends leaving the HV battery in a low charge if you’re leaving the vehicle sitting. (The manual describes it as the EV portion drained and the car is in HV mode).
    3. I don’t have one so I’ll defer to those who have roof racks.
    Basically don’t leave the battery fully garage for long periods of time. Ideally, you drive it as soon as possible after fully charging.
    jerrymildred and HanS0lo like this.
  3. Washingtonian
    Washingtonian Senior Member
    726
    621
    I tried to find a page in the owner's manual that mentioned or recommended that I remove the charging cord once the traction battery has stopped charging so I wouldn't discharge the 12V battery. I typically plug the car in when I return from errands in the afternoon and I may unplug it later that evening when it is charged, or I may leave it for a day or two until the next time I go to the garage. I realize there will always be some parasitic draw on that battery, so if I am gone more than a month I use a battery tender. But why would the charging cable draw current from the 12V battery when not charging?
  4. Salamander_King
    Salamander_King Senior Member
    11,009
    8,935
    New England
    When the charging cable is plugged in, the computer inside of the car always tries to communicate with the battery, inverrter, EVSE, charge port door, charge cable lock, etc. I don't think it is a constant draw, but the periodical check still uses some current. I have checked the resting voltage on the 12v battery with or without the charging cable attached after the traction battery charging has completed. Keeping the charging cable plugged caused ~0.1v drop in the resting voltage of the 12v battery in 24 hour period after completion of charging traction battery compared to removing the charging cord immediately after the completion.
  5. HanS0lo
    WA
    I wish the charging cable can act like a battery tender by let traction battery charge the 12v.
    Anyway, if not driving it for a long period of time, what is the best option for both batteries? Battery tender and charging cable both connected or just the battery tender?
  6. Washingtonian
    726
    621
    Thanks, that was the information that I was looking for. With a tenth of a volt drop in 24 hours, it tells me that it does cause a voltage drop, but I can confidently unplug it the next morning rather than worrying about doing it after exactly five hours and ten minutes from plugging it in.
    Salamander_King likes this.
  7. Salamander_King
    11,009
    8,935
    New England
    For long-term storage (longer than a few weeks), keep the traction battery as low as it can get (depleting the EV range) no charging cable and either remove the 12v battery or connect it to the battery tender would be the best.
  8. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    The choice of roof rack is up to you. The factory rack is OK. Yakima or Thule racks can be wider if that's what you need.
    About your new Prime...the 12v battery does not start the engine--the engine has neither starter nor alternator. The 12v battery powers the electronics that let the system start for either electric or gasoline operation. The 12v battery is recharged from the traction battery under certain conditions. For long storage (have we agreed on how long is long?) a 12v automatic battery maintainer is a very good idea. Battery Tender® is a trademark brand that is one of the good ones; there are others. A nearby 120 volt household-type receptacle is needed to power the battery maintainer.
  9. Sarge
    Sarge Senior Member
    1,323
    778
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    As others mentioned, leaving the battery at full charge can reduce longevity, so the ideal process would be to charge the battery up just before driving. Not always practical of course, and charging early sometimes is not a problem, just try to avoid it when possible. If the car is going to be parked for several days, best to leave the charge at ~50% or less.
    This has been a consideration for us during COVID, since my wife and I have been working from home and barely leave the house. So we only charge our cars (PiP & Leaf) a couple times a week, just before driving, when possible.
    Incidentally, pre-COVID when we commuted daily, our routine was to charge the PiP with the L2 at 7pm (energy prices drop), then before turning in for the night I would swap and plug in the Leaf overnight. My 2014 PiP with 183k KM (~114k mi) now gets about 15-16km on a charge, down from about 17-18, so about a 10-15% reduction in capacity. The Leaf is a 2016 with 65k KM, and we lost the first capacity bar about 2-3 years ago, expecting another to drop off soon, but it does have slowed since shifting our charge behaviour. Anyway, that’s my anecdote. (y)
    As a side note, wouldn’t it be nice if the Prime models had a “vacation mode” feature where you could just leave the car (with or without the HVSE plugged in) and specify the return date while you are away and the computer would automatically maintain the battery at the most ideal SOC for longevity? Seems to me all the tools are there to automatically maintain the battery per ideal health (start up / charge / discharge automatically a small amount for both HV and 12v), the car would just need to know when it is necessary to do this. You listening Toyota?? Where is that suggestion box.... ;):LOL:
    buztabuzt and Tideland Prius like this.
  10. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    It's strange that the manual doesn't mention that batteries degrade faster in a discharged state like they do in a fully charged state. Ideal storage for the lithium chemistry is around the nominal voltage, which is around 3.7V per cell (351.5V for the traction battery). Does anyone know what SOC that corresponds to on the dash? In absolute terms it should be about 30%, but the PP's 0-100% range falls between something like 14% - 85%.
    buztabuzt likes this.
