Question on HV fan function
Discussion in 'Gen 2 Prius Main Forum' started by Joseph Li, Jun 26, 2023.
Tags:
  1. Joseph Li
    Joseph Li Junior Member
    Pittsburgh
    Hello,
    on Gen II, How does the fan function for the HV battery? Does the fan take hot air out or blow cold air in.
    Thanks in advance
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,242
    5,939
    Columbia, SC
    On a Gen 2, the HV battery fan pulls air from the passenger compartment through a vent grate located shoulder high at the rear passenger seat, RH side of the seat. The fresh air blows into the top of the HV battery, down between the individual modules and into the bottom plenum, where it exits the passenger side of the case and goes rearward toward the 12v battery. It exits the car just forward and above the battery, through a louvered opening in the side of the body. The ductwork that exits the bottom of the battery case has a fan control unit mounted in the side of the duct (identical to the unit for controlling the normal vent fan in the front of the car). The top duct has the fan relay clipped into a mounting tab/hole.
  3. Joseph Li
    Pittsburgh
    Thanks a lot, really appreciate it!
