Question on the Intake Manifold cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by paphillyman, Apr 13, 2019.
  1. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    Im wanna do the cleaning on the IM , I took out the air box and the hose for throttle body and unplugged some sensors , but when I got to the manifold itself , there is a wire harness that is clipped to the manifold , I saw "Nuts about Bolts" video and says ya "just squeeze the clips from the backside". I tried getting them out for over a hour with no luck . am I missing something or is there a trick to get the clip off the wiring harness that is clipped to the manifold?
    mikey_t likes this.
  2. Mendel Leisk
    38,873
    Try to determine the orientation of the jaws, with a mirror or your phone or whatever. Try also pushing just one side of the jaws: if you can at least get one side to pop out, maybe the other side will be easier. Pry on the front as you're pinching round back too.
    @NutzAboutBolts does things in a few seconds that take me 10 minutes. I suspect some cases they kinda force those clips, and maybe that's not the end of the world; they're not going anywhere.
    mikey_t and Raytheeagle like this.
  3. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    ty for the tip , btw I was able to clean the MAF sensor so I did get something done !! Will try again tomorrow thanks
    Raytheeagle and bisco like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    I believe the wire harness on the center of the intake manifold has a side clipped setup.
    I have a set of dental picks that help with the job;).
    But the videos are helpful(y).
    Robert Holt likes this.
  5. Mendel Leisk
    38,873
    That's a good idea.
    Raytheeagle likes this.
  6. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Just make sure they stay out in the garage(y).
  7. Mendel Leisk
    38,873
    I use old tooth brushes on the car, dressing the hubs with a little anti-seize for example.
  8. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    I have a good supply of those as well;).
    But we now have a sonic care and the heads are short:cool:.
    So the free ones from the dentist matriculate out in their absence(y).
  9. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    Just got the clips off thanks for the help , without you guys I doubt Id try to tackle this , its suppose to rain the next few days so when the weather looks good and Im off from work Ill do the manifold cleaning , just cleaned the MAF and MAP sensors , again I thank you guys, Gregg
    Raytheeagle and Mendel Leisk like this.
  10. mikey_t
    mikey_t Active Member
    370
    391
    Los Angeles
    Needle-nosed pliers or picks will help. It took me a while to get mine out as well, and I ended up breaking one or two of them by squeezing hard with pliers. I don't worry about it, its not like those parts move around much.
  11. Mendel Leisk
    38,873
    For another example: when you remove the air intake snorkel and air filter box, there's one cable that clips on to the snorkel, around the left side (as you face the engine bay). After taking that stuff off and putting it back on maybe 10 times, that clip pops in and out so easy. The clip jaws are a bit rounded and compressed I guess. And it all still holds together fine.
  12. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    Ya I left mine unclipped until I get to clean the manifold , Im not going through that again
