Question on TPMS Battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GMAccord, Apr 18, 2014.
  1. GMAccord
    GMAccord Junior Member
    After 5 years and 50k miles, my 2009 Prius OEM tires are reaching the tire thread wear marks and I will need to change all soon. Since the tires will be removed from the wheels, Is it a good idea or even possible to change TPMS batteries at this time? I plan to buy at tirerack and get it installed at a local shop.
    By the way I liked the OEM Goodyear. It drove well in summer, rain and heavy snows (I am in Chicago area) and lasted reasonable well.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    You can't change the batteries.
  3. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    When the batteries do run down, you will have to change the sensors. I have not heard of more than 1 or 2 going bad, even on cars older than yours, so I don't think its anything to worry about right now.
  4. Mendel Leisk
    38,875
    I'd be inclined to leave them be, and if the batteries die, continue to leave them be, for the duration of the new tire's time on the rim. And the next time you change tires, maybe still leave them be: TPMS is a great idea, but way too much $ and dealer intervention required in the Toyota iteration, my 2 cents.
    dorunron and vskid3 like this.
  5. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    +1 What Mendel just said.
  6. tampaite
    tampaite Member
    231
    FL
    I just replaced mine on two tires. The battery is sealed and you can't open it to replace it.
    I replaced since the TPMS sign was showing constantly and I couldn't ignore it any longer. Buy online or from a junk yard otherwise it's pricey.
