Question on Traction Battery data re P0A0D
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by LB28760, Dec 16, 2022.
  1. LB28760
    LB28760 New Member
    NC, USA
    Hello everyone!
    Wondering if anyone can confirm my ideas on the information I am getting on Dr Prius regarding a dead traction battery on a 2012 Prius V.
    The vehicle system reads 0% charge on traction battery, as does Dr Prius app.
    What is confusing to me is that the app also shows the battery voltage at 170.22v, which I would assume means it is in fact NOT at 0%?
    I am about to inspect and see if I can find any corrosion around the rear wiring harness that may lead to this fault.
    Of course, I cannot start the engine, BUT, it has tried to start a couple times. I believe the DTC I got after a failed start was P3000. I would clear the code through Dr Prius and also disconnect the 12v battery for a few minutes.
    I have tried reseating the orange breaker-type configuration with no results.
    I am looking at replacing the traction battery but want to be sure that I do not still have issues after that is done.
    Thank you so much for any input! I will also update as to anything I may find.
    #1 LB28760, Dec 16, 2022
    vvillovv likes this.
  2. LB28760
    LB28760 New Member
    NC, USA
    Started getting P0B51 and P3000
    I read that P0B51 could be caused by corrosion and the bars did not look great.
    I removed everything, disassembed and cleaned up the bars and vibrated the nuts in glass for a few hours.
    Upon reassembly I only noticed a slight uptick in overall voltage (didn't expect that) but nothing else. I'm pretty convinced it can't be anything other than the HY battery or battery control (computer), it's just confusing to me that it can show 0% charge while showing +172v.
    Maybe someone can provide me with some insight when/if moderators approve my posts. ;)
  3. rjparker
    rjparker Tu Humilde Sirviente
    9,597
    5,893
    Texas Hill Country
    When a measurement is made without load you often see a float voltage which quickly goes away under load. Capacity is a measure of how long a battery can maintain a given load.
    Hybrid batteries can discharge if sitting for long periods, usually a year or more with a good battery. A marginal battery will discharge quickly because it has low capacity. The dealer can recharge the hv battery in most cases but I would call to verify they have the equipment. Otherwise there are diy techniques that normally require removing the cells and performing individual charge discharge cycles.
    On a 2012 v the original battery is bound to be worn out enough that a recharge might not be worth it. Often there are completely bad cells that won't recharge completely so it becomes necessary to replace them. Buying new cells is the way to go and you get eight to ten more years without thinking about it again. At that point you start saving for a rebuilt engine as the next major expense.
    Tim Jones likes this.
  4. ChapmanF
    17,347
    The battery consists of 168 NiMH cells, and one conservative guideline for when a NiMH cell is fully discharged is when its voltage is down to 1 volt. 170.22 volts from 168 cells is very darned close to 1 volt per cell, so an estimate of 0% state of charge doesn't sound unreasonable.
    Your thread title mentions the code P0A0D, but your actual post doesn't say when you saw that code. That is the code for the safety interlock circuit being open. That'll nearly always be about the handle on the orange service plug, unless you have also been poking at the inverter covers.
    Brian1954 and Tim Jones like this.
  5. Tim Jones
    Tim Jones Senior Member
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    Battery junk.................... just wasting your time checking connections............ get a NEW not USED battery.......... or rebuilt (total joke).....
    And don't buy a exspensive charger that will do nothing but cost you $$$$$$$$$.
    #5 Tim Jones, Dec 16, 2022
  6. vvillovv
    vvillovv Senior Member
    4,318
    1,499
    NY
    First - what voltage would you consider being 0% SOC?
    Second - do you know what nominal voltage of the traction pack is and what nominal voltage means in a battery and/or a battery pack?
    Third - do you know what other prius owners see as a traction packs highest voltage when SOC is at 100%
    Toyota Prius P3000: Check This Before Replacing Your HV Battery | Torque News
    P3000 covers a lot of issues. It's not very informative even when using techstream as in the link above
    The guy diagnosed the issue and narrowed his issue down to the battery cooling fan, but that might not be the problem you are having, but it's one other thing you can look at before you have to deal with your traction packs voltage.
    One picture and a couple of dtc (diagnostic trouble codes) do not make it easy for anyone to give ideas about what might be wrong.
    Sure, we've seen a lot of similar issues, but it never gets any easier to remove the mystery behind all the possible things it might be from what we've read about your prius v so far.
    #6 vvillovv, Dec 16, 2022
    LB28760 likes this.
  7. vvillovv
    4,318
    1,499
    NY
    SOC in a prius is between around 80% soc of the combined batteries in the traction pack when all the cells are fully charged up at 1.5 volts per cell. And at the bottom around 20% soc (of all the cells of whatever NiMH batteries true bottom voltage listed in the NIMH specs) when the SOC gauge in the car and DrPruis app reads 0% SOC
    Knowing the range of voltages that are normal will help reduce confusion.
    Maybe someone else can post how many cells are in each module
    2 modules combined = 1 blade in the DrPrius app.
    If your 12 volt battery read between 8 and 9 volts would that be at 0% SOC?
    #7 vvillovv, Dec 16, 2022
  8. ChapmanF
    17,347
    There are six cells in each module. Two modules in a block. 14 blocks, 28 modules, 168 cells.
    So, as mentioned in #3, 170 volts across the pack is very close to one volt per cell, which many sources will recommend as the cutoff voltage where an NiMH cell is considered fully discharged.
    Brian1954 likes this.
  9. LB28760
    LB28760 New Member
    NC, USA
    Understood. Yeah what happened here is the car was left to sit for a very long time.
    I realized afterwards that the deviation in the pack voltage was the result of a snapshot of a varying measurement..
    I get that, now. I was just interpreting the nomenclature as absolute voltage translating to proportionate SOC.
    I did forget to update that the P0A0D was indeed the safety lock not being fully engaged. After doing that, I was only getting the P3000 and P0B51
    I had read about someone having success with eliminating the P3000 after cleaning all the contacts and they were pretty corroded so I figured it could not hurt anything, at least.
    I merely was interpreting the nomenclature relative to these specific applications as voltage being a direct proportion, top to bottom, of SOC. It hardly seems unreasonable to expect there to be a direct proportion as a logical guess. Clearly that is not the case and that is all that I was asking.
    I understand the concept. I don't think using SOC as a determination of variable applications would be useful in clarifying a pretty straightforward explanation of what Prius considers %SOC in relation to available voltage
    No, I would not consider a 12v battery at 8/9 volts to be 0% SOC in typical context as there is still charge remaining, < 100%. A quite literal interpretation would say 8v would be ~66% of charge of a 12v battery,
    That makes complete sense, I just wasn't looking at it that way.
    I went to pick up a refurbished battery today and it turns out they did not have it in stock. They DID have some blades/cells on hand so I thought what the heck, I am going to try them for now just to see how that works out.
    Dr Prius has identified the potential block issues so I am testing them individually, now.
    Just for reference sake, I am not an absolute pleb when it comes to cars or electrical applications, although my electrical experience is more with AC as a Class 2 Electrician for Northrop Grumman. I also spent a very long stretch as an expert in vintage Jaguars, as well currently own a BMW specialty shop that I have operated for close to 15 years.
    Thank for the replies.
  10. Tim Jones
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    You mean you went to pick up a Old Used Battery........................ I tried all of that stuff....... just a waste of time.....
    GET A NEW TRACTION BATTERY................ just trying to save you frustration and time.............and $$$
    New batteries are $1600......................... what is your time worth. And they keep your battery to resell. If you get a new battery from newpriusbatteries.com you keep your battery and sell it on craigslist to some goof playing around with batteries......I got $300 for mine.
    But next will be the head gasket the brake system... and make sure inverter software up to date because it will blow for sure. If car has 150,000 miles put on a new water pump and check the oil weekly!
    #10 Tim Jones, Dec 17, 2022
  11. ChapmanF
    17,347
    Right—it wasn't a crazy guess, it just isn't the way batteries work, and now you know. :)
    That still isn't the way batteries work. For each different battery chemistry, there will be a certain voltage that means effectively full discharge. For NiMH, that's about a volt per cell. For lead-acid, about a volt and three-quarters per cell, or around 10.5 volts in a six-cell 12 V battery.
    A 12-volt battery reading 8 or 9 volts would be one that was taken down to 0% SoC and then further abused a couple volts below that.
    Also, even above that minimum voltage, and from there up to 100% SoC, the voltage-to-SoC curve doesn't have to be even close to a straight line. Some batteries can exhibit nearly constant voltage through most of their charge range, then drop off much more steeply at low states of charge. A battery-management system might be comparing voltages to a very accurate model of that curve, or actually counting coulombs of charge going in and out, or both. Simple off-the-cuff guesses about voltage and SoC won't often be very close.
    LB28760 and Tim Jones like this.
  12. vvillovv
    4,318
    1,499
    NY
    I'm glad you were able to get more info from both other members and from DrPrius .
    There are so many variables in methods and what some seem to think are standard definitions of measurements in batteries or the properties of DC and the tools used to measure and charge/discharge them, it's near beyond description. Didn't mean to ruffle any feathers, but I also didn't want to start a new discussion on the subject either, since that usually causes more heat than benefits anyone.
  13. LB28760
    LB28760 New Member
    NC, USA
    Oh no not at all, no ruffling here haha.
    It appears most likely that the installers that do not require a core (those that are understandably more expensive) and the only ones that are likely to have a literally brand new battery.
    The very reason the less expensive installers require a core is that is exatly the part they will refurbish and resell (See: "refurbish" (cycle) the cells as well as balance and charge the whole battery array)
    I went with what was at hand. I went to buy a refurbished battery {as I said, I didn't mean anything other than what I said) and not pay for the installation as I didn't require it.
    Had that worked as planned it would have been a simple matter of taking it home and installing.
    Sure, it was time consuming to balance all the cells manually with a desktop power supply but it appears to have worked out fine.
    This is a friends car and they have more time than money.
    Sure, this battery caused me much more hassle and time but I'm trying to work within their parameters.
    Turns out what they anticipated as a "head gasket" issue was far worse, and the reason the engine wouldn't start even with a decent charge is it was froze up tight.
    It's been replaced now with a low mileage JDM engine.
    Added bonus: the EGR cooler on the JDM engine was pristine!
  14. rjparker
    9,597
    5,893
    Texas Hill Country
    So the odds are good the original oem battery was good. Perhaps better than the so called refurb which could have been from core batteries years older.
  15. Tim Jones
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    Next thing will be the battery........... blown inverter then the brakes and quite possibly another head gasket or burning oil..... or both
  16. LB28760
    LB28760 New Member
    NC, USA
    In theory, yes. Very likely the battery would have functioned properly, although 2-3 of the modules were definitely on the way out.
    Dr Prius app helped me look at which blades to single out, and I went ahead and charged/load tested all the remaining blades and it all looks to be in a good condition, now.
    Only issue I am potentially looking at is Dr Prius showing proper voltage but zero SOC. I am assuming this is something with the lock out and should be easy to track down once the last modules (5&6, right at the safety lock out so they got skipped in charging) are charged and I can read the codes.
    You mean the 12v? It's new and all the modules in the HV/Traction battery have been extensively tested and all seem to be in great condition.
    As far as head gasket or burning oil: JDM are a fantastic resource for replacement/upgrade engines. I know people that have drawn on this for many years with great success.
    The reason for their availability is the tremendously strict emissions regulations in Japan. Once an engine reaches 100,000km, it is easier to replace the engine than try and make the original engine meet specs.
    As a result, all of the available engines are <60k miles and cost 50% or less than used engines in the US with 3x the mileage.
  17. LB28760
    LB28760 New Member
    NC, USA
    If it were MY car, I would absolutely go with the NexPower Lithium upgrade, for not much more than a brand new NiMh.
    Tim Jones and Air_Boss like this.
  18. LB28760
    LB28760 New Member
    NC, USA
    Well I am sort of back at square one with voltage/SOC.
    Does the light green mean that only #12 is in the proper range, and I need to charge all the others more?
    Clearly in a much better position now that at the beginning. I'm in the process of bringing module 3 up to closer to balanced.
    It's been a bit of whack a mole charging 2 modules at a time, they don't always end up with even charge.
    I did NOT read the current DTC codes so there is a possibility that will tell me something but I feel this "0% SOC" is an intermittent thing and am leaning towards it being an issue with the safety lock out mechanism/connection.
    Once module 3 is up to 15.23v I will reconnect and check OBC codes.
    #18 LB28760, Feb 14, 2023
  19. Brian1954
    Brian1954 Senior Member
    1,814
    719
    South Central PA, USA
    Have you started the car and driven it for at least 15 minutes?
    The battery SOC% is calculated by the ECU after you drive the car. It is not instantly calculation based on the battery voltage.
    I am not an HV battery expert, but charging all 14 blocks (2 modules=1block) to the same voltage does not mean your battery pack is balanced.
    #19 Brian1954, Feb 14, 2023
  20. LB28760
    LB28760 New Member
    NC, USA
    Not yet, haven't had enough voltage to start, or at least that is what it appears to be. .
    There's so much conflicting information out there.
    I have found that 15.7v/module is barely enough to register as SOC.
    I found that when aiming more towards 16v+/module I am actually seeing a percentage of SOC. I wasn't sure if not seeing this was a fault condition or something else.
    Turns out the monitoring is working fine, there just wasn't enough voltage presence to register.
    I'm changing everything to 8v/blade to see what results that provides.
