Question: Piston Steam Cleaned
Discussion in 'Gen 3 Prius Main Forum' started by Prius V 301, Dec 31, 2023.
  1. Prius V 301
    Prius V 301 Junior Member
    Silver Spring MD
    2013 Prius v wagon
    Recently, experienced my first knocking start up. I believe it is the head gasket. Could anyone tell me if my piston tops look like they have been steam cleaned?
    Mileage: 130k
    Replaced EGR valve, spark plugs, Intake manifold and cooler at 110k.
    https://photos.app.goo.gl/h7hLkyJxZBvcQHe66
    Sorry for the google photos link. I am having trouble uploading pictures to Priuschat.
    #1 Prius V 301, Dec 31, 2023
  2. Mendel Leisk
    40,581
    Are the pistons numbers 1 through 3, top row from left to right, and number 4 in second row?
    Addendum: Actually the second row pic looks to be same as left end of top row, albeit with enhanced contrast??
  3. Prius V 301
    Silver Spring MD
    2013 Prius v wagon
    Yup your correct pistons 1-3 are top row and 4 is on the bottom. Thanks for catching that, I corrected my mistake.
  4. Tombukt2
    Tombukt2 Senior Member
    12,206
    2,152
    Durham NC
    I don't think in the early stages of the failure you have enough water coming in to clean up the piston crowns like you would see with a big leak That's how we used to break up carbon off the piston tops and the valves and what not in the old days by running water through the system or a vapor and could see sometimes golf ball size pieces of carbon and black stuff hitting your garage door
  5. BiomedO1
    BiomedO1 Senior Member
    2,816
    1,498
    SacTown, Ca
    To answer your question, yes you've got moisture leaking into your combustion chamber. Normally, your piston tops should be black, not clean, like your pictures.
  6. Mendel Leisk
    40,581
    They’re quite uniform though. Often with 3rd Gen head gasket failure, 2 through 4 are really sooty, and 1 significantly cleaner. Early stage?
    Tombukt2 likes this.
  7. Prius V 301
    Silver Spring MD
    2013 Prius v wagon
    I agree! I was expecting piston 1 too be cleaner then 2-4. I am torn now if I should take a chance and see if the knocking gets worst or should I go ahead and change out the head gasket.
  8. Mendel Leisk
    40,581
    You could try pressurizing the coolant system with the boroscope in there, look for coolant tears. The Car Care Nut has a video on this. Does your boroscope have a reverse viewing lens you can flip too? So you can look back up at the seam between block and head.
    If no tears, cross fingers and clean EGR/intake?
