Question: Rear Dashcam Wiring Grommet
Discussion in 'Gen 5 Prius Accessories and Modifications' started by scotched, Jan 26, 2025.
  1. scotched
    scotched Member
    66
    87
    Encino, CA
    2023 Prius
    I just finished running USB cable through the rear hatch via the grommet.
    It was suspiciously easy to do compared to the CT200h - very flexible shape and easy to "fish" through.
    When putting the grommet back into its hole I get the audible click, but I get the sense that it's not putting enough pressure on the hole to make it water-tight.
    For those who did this: Did you tuck any of that surrounding rubber into the hole? I just don't want to end up with water in my headliner. Ask me how I know.
  2. purplePriii
    purplePriii Active Member
    275
    122
    I did the same thing but I'm pretty sure mine looked like yours at the end. I tried pushing it in a bit more but it didn't seem to do anything. If anything, you can compare with the one on the left side of the car. My trunk had one of these on both sides so I used the other as a reference when done.
  3. scotched
    scotched Member
    66
    87
    Encino, CA
    2023 Prius
    Yea I was comparing left and right when I reinstalled the grommet. Very hard to tell any difference. The outside rubber seems "tight" on both.
    Since you live in Canada - have you been through a bunch of rainy days? No leaks into headliner?
  4. Perfectpacman
    Perfectpacman Junior Member
    84
    22
    United Kingdom
    2024 Prius
    ----UK----
    Once it clicks, that's the seal against the steel.
    scotched likes this.
  5. purplePriii
    275
    122
    I've been around with the car but I did experience a ton of rain and so far so good, I haven't noticed anything with the headliner and it's been about a year I did this on mine.
  6. scotched
    scotched Member
    66
    87
    Encino, CA
    2023 Prius
    It survived our first rain event (a rarity here).
