Question Regarding Breaking on Ice
Discussion in 'Gen 2 Prius Technical Discussion' started by greylar, Jun 2, 2008.
  1. greylar
    greylar New Member
    283
    38
    Montana
    I have done a moderate amount of searching on this and can't find anything directly related to my questions. These questions are related to a very specific situation that happens with regular front wheel drive vehicles on ice so let me define that before I ask the question.
    When traveling on ice at a higher rate of speed, (say above 35), in a front wheel drive vehicle it will occasionally happen that when letting off the gas the back of the vehicle will come around in a spin. This is a result of the braking action of the engine compression during deceleration on only the front wheels. The physics are a little beyond me but the front of the vehicle is essentially being held in place by the tires causing the back to break free and spin around.
    Rear wheel drive vehicles don't have this problem since the rear wheels are the ones causing the drag and tend to pull the car straight. Many people that go in the ditch on icy roads as a result of this effect. It should be noted that braking can cause the problem as well but not usually since the forces of braking are more evenly distributed in a properly functioning braking system, but I have been in a vehicle where one or both of the rear brakes were not working properly and the effect is greatly magnified. The real solution is to not let engine compression slow the vehicle by either clutching or putting it into neutral and then use the steering for collision avoidance.
    Now to my questions:
    Since the Prius has a regenerative braking system which uses the drive wheels only during braking in most circumstances, except hard braking, (i am making an assumption here) it occurred to me that in the situation as outlined above the Prius would act just like deceleration except somewhat compounded by the greater force of breaking.
    Am I wrong in assuming that the brakes are not used at all in the Prius under normal braking conditions above the threshold speed (7mph??)?
    Or when braking, does the Prius regenerate on the front brakes and use the friction brakes in the back for distributed braking?
    If my assumptions are correct how might the Prius might mitigate this effect?
    Thanks,
    G
  2. Bob64
    1,540
    92
    Virginia
    While I don't claim to be an expert on prius braking, and may be totally incorrect
    1) Regenerative braking is disabled when the traction control light goes off, ie when the prius notices the wheels start to slip, like on ice.
    2) the prius has disk brakes in the front and drum brakes on the rear.
    3) all braking is dependent on the availability of traction... if the tires can't get any, the prius will follow newton's first law of motion... and go into a straight line.
    4) one of the reasons why the rear tends to fishtail is because the weight of the engine/transmission is more focused on the front, instead of being evenly distributed... thus the front has more traction.
  3. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
    I believe that when you take your feet off of both the accelerator and the breaks, that there is some regeneration happening that slows the car down a bit more than just friction and aerodynamics. So this is a slight negative for the Prius on ice, IMO.
    BUT, the Prius engine does not slow the car as much as a normal engine in a normal car (unless you are in B mode on tranny), so this is a slight positive for the Prius on ICE.
    My suspicion is that the slight positive outweighs the slight negative and/or they are so close as to be a wash.
    Yes, I believe that the brakes are not used at all in the Prius under normal (moderate) braking conditions above the threshold speed.
    No, I think regeneration on the front is not normally combined with braking in the rear, unless braking is hard enough the front brakes are activated also.
    These are my thoughts and understandings. If someone thinks I'm wrong, I'm sure they'll pipe up.
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    First off, can we please get the word right? BRAKING. Not
    breaking. You want your prius to BRAKE, not break. It breaks
    when it slews around sideways and hits something, probably due
    to poor braking technique.
    Front wheel braking is probably not the main cause of rear end
    spin, and in fact allowing those wheels to keep turning probably
    helps keep things on an even keel rather than destabilizing.
    Ask any trucker about trailer brakes in snow. If you've somehow
    put enough sideways force on the rear end to slide it, it will
    probably do so with or without the wheels turning because you've
    overcome whatever side friction the rear tires have left.
    In fact it's pretty hard to spin this car *unless* you stab the
    e-brake to deliberately lock up the rear end, and you have to
    help it quite a bit by going into a pretty tight turn beforehand.
    Playing around in empty, snowy parking lots is really good practice.
    _H*
  5. greylar
    greylar New Member
    283
    38
    Montana
    Thanks Hobbit, I corrected what I could on the spelling. Thanks for the heads up. From what I have read it appears pretty stable on ice however given that the rear brakes don't engage most of the time it will change my driving habits in slick conditions. The situation I am talking about is very specific but none the less it happens around here a couple times a year. And I have had front wheel drive vehicles slide out under engine compression.
    Thanks for the help.
    G
  6. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    On top of what's been said before, your Prius has Vehicle Stability Control, with sensors that look at your steering angle and the car's yaw. If the back end starts to slide one way or the other, VSC applies force in the other direction to maintain steering direction. Applying force could mean a little braking on one wheel, or reducing braking on another.
    If you are driving on Goodyear Integrity slicks by next winter and happen to drive on a sheet of ice, your tires will have no traction anyway, so no amount of VSC can help you. Winter driving means having appropriate tires and driving appropriately for speed and conditions.
  7. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    As Hobbit said, engine braking on the front wheels will not usually cause the car to spin because the rear wheels are turning with no force slowing them (unless you apply some).
    Example - I had a Subaru Wagon 4WD (older model - manually shiftable). In FWD it would become "unstable" on ice, but wouldn't spin, just scare me by "wandering". I would shift it to 4WD and that would stabilize it, because it locked the front and rear wheels together. But it would handle "funny" in corners that way due to the front/rear lockup. The current Subarus don't do that as they have clutchs/diffs. in the front to rear drive.
    Example 2 - I was following a small pickup on the highway in winter (in the Subaru). Unknowingly we entered a 5 mile stretch of highway that had just been hit with freezing rain. We were doing 80 km/hr (50 MPH). I didn't notice anything happening to me, but he started to loose the rear one way, then the other, etc. He almost recovered, but then it snapped in one direction and he went head on into the ditch (at low speed thankfully). It took me 3 miles to come to a stop from about 60 km/hr (40 MPH or so). Now THAT was slippery!
    Example 3 - I only have one winter with Pearl so far. I drove in freezing rain twice. No problems whatsoever (city only). I do have good tires on the car (Nokian WR which are rated as good as the Mich. "Ice tire"). I leave them on all summer as well. I did see the anti-lock light a few times while braking, but mostly tripped the cars' systems when accelerating (traction control) and twice in a corner (VSC). Under normal accel or braking I had no problems all winter. I even tripped the traction control last week on some still not cleaned up winter sand/gravel when taking off around a corner from a light. :)
  8. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    I run very aggressive studded snow tires in winter. Available at Canadian Tire as the Goodyear Nordic, it's the same as the Goodyear Ultra Grip 500 sold in Europe
    Goodyear Eur-Winter Tire-UltraGrip 500
    With these tires on, I never worry about icy roads myself. I just make sure when I hit the brakes, that nobody is behind me. The tires really do work that well
    I've never had any issues with stability or traction on ice, running the aggressive studded winter tires. Though last winter, I did witness a brand new Ford F-450 do a very interesting spin on ice at Deacon's Corner.
