Questions about battery/mpg/possible problem
Discussion in 'Gen 2 Prius Main Forum' started by Etel Rose, Jan 1, 2007.
  1. Etel Rose
    Etel Rose New Member
    37
    Hello! I have a few questions. I'm sorry if they are answered elsewhere on the forum. I wasn't able to find an answer in my manual and I think that the people here collectively can possibly give better advice at this point than the dealer and maybe even service department.
    My car now has 4100 miles on it. The average for the first 2,000 miles was between 46.8 and 51.8 mpg per tank. In November my mpg took a dive - and has ranged between 36.1 and 43.9 mpg. I don't know why. It's not tire pressure. The weather has been moderate; I'm in the mid pacific NW. Although I do notice that the heat needs the gas motor, I don't know that this could be responsible for this change; and I did use the air conditioner in the summer. The only other possible change is that I believe ethanol is added to the gas here in early November. I don't know if that would make a difference.
    The other thing that has happened only within the past week is as follows. Prior to this, my battery charge would be displayed with blue bars 95%+ of the time. It would only show the fuller charge with the light green bars when I would have a long stretch of coasting, maybe applying some break or B gear. The green bars would quickly then disappear and drop down to blue.
    In the past approximately week, the battery has displayed its charge with the light green bars about 80% of the time. I'm doing nothing special or different. And if it's showing light green, and I go into a store or something for a little bit, then come out and start up, I still show the light green. That would never have happened before. My mpg has not changed within the last week, but I don't know what to make of this change. I think something may be wrong?
    So, I'm concerned about the significantly dropped mpg during the past 2,000 miles, as well as the sudden switch to a preponderance of light green bar battery charge. I also had assumed that the light green bars were good, but I read somewhere on here that it was actually not good to be in the green, although I don't know why, and I may not have understood that post.
    Do I need to take my car in? I'm concerned that without something more insightful to tell the service department, they won't understand this car well enough to know whether any of this is a problem. Any ideas about what's happening? Thanks.
  2. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    I personally don't think there is anything wrong with your car. Mpg can lower due to short trips also, especially in the cold. For me, I had over 50 for the first 2-3000 miles or so (with warm weather and long highway trips), but now it is probably in the low 40's since I take a lot of 5-10 min drives and it is cold.
    The battary charges and discharges depending on how you drive and the roads, may be you are coasting more these days even you don't think you do :)
    I might be wrong, but by reading your post, I don't see any trouble. :)
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Sounds like typical cold weather behavior. Even though you say it's not your tire pressure, have you actually checked them since the weather turned colder?
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    The good news: There's probably nothing wrong with your car.
    The bad news: It's going to do this every winter.
    You are right about winter gas, it gives us poor mileage. It did the same thing with your previous car but like most of us you didn't notice. As previously stated the engine needs to run more to keep the catalytic converter warm, keep heat in the car, etc. Even a mild winter is cold enough to make a big difference. I have seen a 5 to 10 MPG drop since Summer. But it will come back up again. :)
  5. nicoss
    nicoss New Member
    304
    I’ve also noticed a drop in MPG (from 48/49 to 43/44) when I use Shell gas; it goes up again when I put Mobil.
    (Always use the same Shell or Mobil station and have tried almost all the pumps in each one)
  6. paulccullen
    paulccullen New Member
    276
    Seattle, WA
    Another possibility: Low tire pressure.
    This happened to me a few months back. I saw my MPG drop to the low 40's for no appearant reason. It turns out I had a very slow leak in one of my tires. Now I check the pressure regularly :)
    Altho' I don't recall seeing an increased SOC as a result.
    <Oops! Sorry, just re-read your post, it's not tire pressure>
  7. daniel
    14,487
    1,518
    Spokane, WA
    I vote for typical cold-weather behavior, which would explain both the lowered mpg and the higher battery SOC.
    Cold weather (or more properly, demand for cabin heat) causes the engine to run more. This lowers your mpg and also leads to the battery being generally more charged. Additionally, cold weather means the battery is colder when you start up in the morning, and a cold battery is less efficient and therefore produces lower mpg.
    None of this is bad for the car, and none of it is a malfunction. Of course, lower mpg is "bad," but only in the sense that the car burns more gas in cold weather.
    It will go back to the way it was when summer returns. Just be glad you don't live in a really cold climate, where you could, under the "right" conditions, see mpg as low as 30.
  8. Etel Rose
    37
    <div class='quotetop'>QUOTE(daniel @ Jan 1 2007, 05:20 PM) [snapback]369327[/snapback]</div>
    O.k. But does anyone else run about 80% of the time with the display showing the green bars? For awhile it's been in the 30's to 60's here (I'm guessing), so it's not really cold. This hasn't changed much over the last week. And the places I drive and my driving habits haven't changed. So why the SUDDEN switch to charging so much battery (and saving the charge even after I stop the car and restart later). This isn't normal at least for this particular car...?
  9. prius62
    prius62 Junior Member
    45
    <div class='quotetop'>QUOTE(Etel Rose @ Jan 1 2007, 03:31 PM) [snapback]369350[/snapback]</div>
    If you aren't sure ....I say take it to the dealer. I noticed an electical smell in my recently purchased '05 and they said they needed to change the computer. Bottom line for me is that this is a unique machine and if you think there may ne something wrong...tale it to the folks who know best. No flames please, I know the dealership isn't perfect.
    100 mile a day communte for me and this site has been fantastic....thanks to all.
  10. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    <div class='quotetop'>QUOTE(Etel Rose @ Jan 1 2007, 06:31 PM) [snapback]369350[/snapback]</div>
    Mine shows green bars most of the time since it got colder. As someone else said, the engine runs more to give you heat and that keeps the battery more fully charged than in the summer. I just got back from a trip to Florida and while down there, with temps around 80F, I hardly saw green bars at all.
  11. efusco
    19,891
    1,192
    Nixa, MO
    Yup, depending upon your commute, your heat settings, your driving technique, etc you'll see green much more often in cooler temps. I did a lot my first year with the Prius...I've since altered my driving style and see it less, but even with my style of driving my winter average SOC is higher.
    Take it to the dealer if you need the peace of mind...but it's normal.
  12. Etel Rose
    37
    <div class='quotetop'>QUOTE(efusco @ Jan 2 2007, 12:05 AM) [snapback]369360[/snapback]</div>
    Thank you all for the responses, and any more to come. I still don't understand the sudden change, but this is at least helping to ease my mind that my car is probably o.k. :)
    (BTW I said not the tire pressure because I have gotten the tire pressure checked regularly).
    If you have a sec, how did you alter your driving style such that you're seeing the green bars less?
    I'm wondering if anyone knows for sure: Is it the case with the extended warranty that you get a free loaner car when diagnosis/repairs are being made for parts under warranty?
    Thanks.
  13. Ken Cooper
    Ken Cooper New Member
    339
    I wouldn't rule out the batteries.
    There's almost 36,000 miles on my car. It's gone through 3 summers and this is its 3rd winter. The first year it averaged 48 to 49 mpg. The second year was 45 to 46 mpg, and right now it's down to 39 to 40 mpg. Not so long ago in a post I bragged that the car had never experienced lower than 44 mpg. Now it never gets that high. It's been serviced at least every 5000 miles by Toyota. I've been on this forum since late 2003 and have followed all suggestions aimed at addressing mileage problems.
    I've read where Prius battery failures are very rare, but I've not read anything on the topic of battery degredation. With a loss of 10 mpg after 33 months but with everything about the car seemingly working just fine, I'm beginning to believe my battery simply does not yield the same current per given time as it used to. Assuming that's the case, the internal combustion engine has to do more of the work than before. I've never known any other of my rechargable batteries to not degrade over time. I can't see why the Prius batteries would be any different.
    The battery does show green bars when, for instance, I drive from the heights to the valley - a change in elevation of of about 1000 feet - takes about 20 minutes), under typical driving conditions it shows some number of blue bars, and when I drive from the valley to the heights it typically gets down to 1 to 3 purple bars. So .. The battery display doesn't seem all that different than when I first bought the car.
    This mileage thing is pretty dissappointing. I'll be taking the car in soon and will report the poor mileage as a problem that needs to be corrected. I would imagine the Toyota service department would have some apparatus for checking the effectiveness of the batteries. If so, I'm hoping they'll make that check and let me know the results.
  14. efusco
    19,891
    1,192
    Nixa, MO
    Just b/c you have the tire pressure set every 5k miles doesn't mean much...when the temperture drops so will your tire pressure...are you having the pressure checked on cold tires...ie. not driven for 2-4 hours before checking? Do you check w/ weather changes?
    I doubt they'll give you a rental for something like this and they may not even cover it under warranty if there's no actual problem...but most places will, esp. in the first 12mo/12k miles.
  15. Etel Rose
    37
    <div class='quotetop'>QUOTE(efusco @ Jan 2 2007, 02:45 AM) [snapback]369513[/snapback]</div>
    Well, I haven't had the car for 5K miles yet. I have the tires checked/inflated every month.
    I don't have the extended warranty, but I thought I might buy it sooner rather than later if it meant I could get a loaner if something goes wrong with the battery or something like this...
  16. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    ya your mileage is normal stuff. noticed the drop in Nov??? from a tank that was filled up AFTER Oct 15th???
    i ask because i live a hundred miles north of you and our area went to winter formula gas on Oct 15th. that is an instant 3-6% drop in gas mileage. so boom, thats 1-3 mpg.
    average increase in air density is actually what will cause the greatest change in your mileage. that can be as much as 15% in the winter but you are right, the weather is mild here, but the air density is not, much higher humidity can affect mileage as well... something about the unfriendliness of burning wet air as opposed to dry air... but around here, that is another 2-5 mpg and much more on those occasional cold snaps.
    increased rolling friction is another lesser factor caused from driving on wet pavement... amount varies by how much rain we get but during those very heavy storms we had when standing water on the freeway was present, i could see my instantaneous mileage drop AS I DROVE THRU the puddles. that is a huge cost getting back up or maintaining speed.
    colder weather does mean slightly lower air pressure on your tires, its a good time to check your pressure. best time is after the car has sat overnight early in the morning
    so, should you get less mileage?
    ya you should.
    in the summer my minimal average is 55 mpg, runs as high as 62 mpg for a tank. in the winter i run 49-52 mpg and only because i completely block my radiator from getting any air flow (helps keep the ICE warm) im pretty sure that will boost your mileage at least 2-4 mpg as it has mine.
    after a few weeks, which included several trips of more than 50 miles of mixed driving, i have yet to see a water temp of over 211ºF, (dont have CANVIEW so cant monitor engine and converter temps which is the better way to go) and at that temp, the circulation fan never comes on so its got to be in the normal range.
    also, if the temps are in the high 30's or lower, my max water temp usually doesnt get above 175ºF and i know that is not anywhere near warm enough. (thermostat does not open until 190-195º) on my short commute. that lowers my mileage to 39-44 mpg. same trip that gets me 60-70 mpg in the summer time.
  17. daniel
    14,487
    1,518
    Spokane, WA
    Dave's post above (not the whole thread) should be in a sticky post for everyone going into their first winter with a Prius and wondering about mileage!
