Questions About Display, AC
Discussion in 'Prime Main Forum (2017-2022)' started by Mutant-Man, Aug 6, 2021.
  1. Mutant-Man
    Mutant-Man Junior Member
    Cleveland
    Greetings, everyone. I have a 2021 XLE (got it back in March), which replaced my beloved 2006 Prius. So far, I like the way the vehicle drives (though it is relatively sluggish in HV mode), but I find that the large touch screen and layer upon layer of menus is confusing. I have a few questions I'm hoping someone here can help with.
    1) Is there a way to turn the display OFF with one button push, or with a double-tap of a certain button? In the old Prius, tapping one of the keys (climate, info, etc) and then tapping it again would turn the display on and then back off. In the Prime, it seems like the only way to do this is to push HOME, DISPLAY, and then OFF. The icons are small, and frankly I find it distracting to do it while driving. Am I missing something? Is there a shortcut?
    2) Is there a way from the steering wheel controls to turn the AC OFF? I've found that you can turn the AC ON using the steering wheel controls, but you can't turn it OFF using those same controls. Instead, you have to open up the touch screen, push climate, then push off. While driving, that's a lot of fussing, and it again strikes me as something that is pretty distracting.
    3) The info next to my speedometer changed a few weeks ago, and I don't know why. It used to show me what it thought was the speed limit in a given area (not always correct lol), but now it shows me a meter with CHARGE (which fills when I brake), EV, and POWER. And to be clear, this is not something I can change by pushing the left/right arrows on the right hand side of the steering wheel. Those arrows cycle me through climate, audio, info, etc. I just don't get it, because for the first 3 months I had my car I got used to seeing the speed limits next to the speedometer, and then one day that info was gone and was replaced with something else. Did Toyota change something? If it's something I inadvertently did, how can I change it back?
    Many, many thanks for everyone's assistance.
    dig4dirt likes this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,153
    Tampa, FL
    Not that I've ever heard of.
    Don't think so. I've just learned to deal with the poorly designed display. The map is always at the top using space whether I'm using it or not. I generally keep the climate control at the bottom.
    Do you mean this?
    It is set with the buttons on the right of the steering wheel. The meter you refer to is the HSI (Hybrid System Indicator) and it's far more useful than the car's guess at the speed limit.
    Mutant-Man likes this.
  3. Mutant-Man
    Cleveland
    Thanks for your detailed reply.
    That’s pretty awful that there’s not an easier/simpler/safer way to turn off the screen, or to turn off the climate controls. I guess I didn’t realize you could mode the climate controls to the top and the map to the bottom, or am I misinterpreting you?
    As far as the other issue, when I have the compass up, there’s not any info there about the speed limit. That, and when that info used to be visible, it was immediately to the right of the speedometer and always stayed there, no matter which menu (music, climate, info, etc) I scrolled through using the sideways arrows on the right side of the steering wheel. It was always like this until one day it suddenly wasn’t, and then the only thing I could scroll through (using the up and down arrows) were three slightly different displays relating to energy efficiency/usage.
    Here’s what I see on my dash:
  4. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    You must have somehow turned off the RSA (Road Sign Assist) in your setting. So that you are now seeing the Split Screen info on the spot where RAS use to display. Toyota implemented TSS2.0 with RSA on 2021 model PP as an afterthought. They did not have a place to display the RSA info such as speed limit, without disabling the more valuable split screen information. On your split-screen, you can toggle seeing mpg or miles/kWh efficiency depending on which mode HV or EV you are on, battery SoC, or Hybrid System Indicator.
    Go to setting and toggle the RSA back to ON, then you will see the RSA information (i.e. speed limit) again on the position of the split-screen right to the speedometer.
    BTW, I have RSA turned off and keep the miles/kWh (or mpg if in HV mode) on my split-screen. It is far more useful information for me than showing the speed limit which no one ever obeys anyway.
    #4 Salamander_King, Aug 7, 2021
    Mutant-Man, jerrymildred and dig4dirt like this.
  5. jerrymildred
    11,517
    14,153
    Tampa, FL
    You misinterpreted me. The options for the bottom are climate, sound, and a few other things like the mpg bar chart. Or nothing at the bottom and the whole screen occupied by the map. The only thing that can be at the top is either the map (when the bottom of the screen is otherwise occupied) or the top half of the map.
  6. Mutant-Man
    Cleveland
    This did the trick! Thank you! I'm not sure I will use the feature, but I was wondering why it had suddenly disappeared.
    Two other quick questions. Does the XLE have blind spot monitoring? I read that it did, but for the life of me I can't find a setting for it anywhere, and in my now 5 months of driving the car it's never once come on, which seems unlikely.
    The other question relates the three buttons just below the touch screen: Drive Mode, EV/HV, and (I think) EV Auto. The first two are pretty self-explanatory, but I've never quite understood that last one, either what it does or how it works.
  7. Mutant-Man
    Cleveland
    Got it. For a second I got excited and thought maybe I could do something a little better that space. I guess it does improve slightly in CarPlay, since that allows you to display a few other things along the top. I have to admit, though: one of the things I most miss about my 2006 is the simplicity of that screen. The icons were so few, and big enough, that I could operate them all from memory without having to look at the screen. But with this new one...
  8. Db17
    Db17 Member
    188
    92
    Visalia, CA
    No blind spot monitoring on XLE, Premium/LTD only.
  9. Salamander_King
    11,019
    8,954
    New England
    #1. No. PP XLE does not come with BSM. On PP, only Limited trim has that feature. IIRC, on regular Prius and eAWD Prius, I believe BSM is standard on all trims.
    #2. The last switch is for EV-Auto mode. In that mode, the car will make changes between EV and HV automatically as you drive. In theory, the car will switch to HV mode in high power demand situations such as merging into a highway or climbing a steep incline. But in my experience, EV-Auto only shifts to HV mode if you floor the pedal full throttle. I almost never drive like that for my regular commuting. Therefore, for all practical purposes for my driving conditions, EV-Auto behaves exactly the same as EV mode that is it stays as EV mode until the traction battery depletes the EV range then HV mode starts automatically.
    BTW, there is another mode that does not have a dedicated button. You push and hold the EV/HV button, then you enter Charge Mode. In this mode, the engine will run to generate electricity and replenish the traction battery up to 80%. However, the efficiency drops quite a bit. Unless you have a very good reason that you need the traction battery charged this way, you will be better off just driving on HV mode.
    #9 Salamander_King, Aug 8, 2021
    jerrymildred likes this.
  10. jerrymildred
    11,517
    14,153
    Tampa, FL
    I believe you mean Advanced/LTD only. Premium is like mid grade like XLE.
    Db17 likes this.
  11. Ovation
    Ovation Active Member
    156
    130
    Quebec
    That has not been my experience. I often select EV Auto once I am on the autoroute or interstate (depending on which side of the border I find myself) and it behaves as you describe in theory. Perhaps there is a velocity threshold or it works more effectively in conjunction with DCC (usually on when I’m in EV Auto mode).
    Salamander_King likes this.
  12. Salamander_King
    11,019
    8,954
    New England
    It is possible that Toyota might have adjusted the EV-Auto threshold for the engine to kick in. My experiences were limited to my previous 2017 PP. After several attempts on using EV-Auto on the 2017 PP, I could never get the engine to come on unless I floored the pedal which I almost never do for my driving habit. I did not drive my 2020 PP enough to even test that feature. I will have to test the EV-Auto responsiveness on my new 2022 PP. As you said, the speed may also come into play. I almost never drive my PP on EV mode on the interstate where I get above 65mph. My regular commuting is on rural state highways and roads with speeds less than 50mph. My average speed for commuting is well below 30mph.
  13. jerrymildred
    11,517
    14,153
    Tampa, FL
    With my 2017, even if I floor it and keep it floored for several seconds in EV Auto, the ICE won't come on.
  14. Salamander_King
    11,019
    8,954
    New England
    Well, I just came back from running an errand. I drove my 2021 PP all the way on EV-Auto. 33.5 miles EV only. The engine never fired up. The average speed was 32mph, but at a segment, the top speed reached 56mph briefly. I did not try flooring the pedal on this trip. I will try that later on a road where I can do that safely. But it is safe to assume that Toyota has not changed the EV-Auto threshold substantially from the 2017 model. For all practical purposes, for my regular driving conditions, EV-Auto mode behaves just like EV mode.
    BTW, this was with a full charge in the battery. After the 33.5miles round trip, the car still had 11% SoC left on the gauge. I am averaging ~35 miles on a full charge. I drove 37.6 miles yesterday all on EV before it switched to HV.
    #14 Salamander_King, Aug 9, 2021
    Happy Dance and jerrymildred like this.
  15. jerrymildred
    11,517
    14,153
    Tampa, FL
    I've also tried EV/Auto on the Interstate at over 70 mph. ICE never came on.
  16. Ovation
    156
    130
    Quebec
    Did for me yesterday in NH. No stomping on the pedal. Did have DCC on. Perhaps that’s the key.
